  • Member For: 12y 5d
  On 31/05/2013 at 9:41 AM, Paulie2256 said:
Did you have a look at an fg sump?
No I just looked an a BA. Are the FGs vastly different?
  • Moderating Team
  • Member For: 22y 3m 9d
  On 22/05/2013 at 11:12 AM, Woznaldo said:
Rubbish handling though......
yeah we are too busy going fast in a straight line, to worry about corners and other unnecessaries....
My comment was probably a bit harsh, but the leaf springs in the Ute aren't exactly cutting edge, especially when compared to the sedan's Multi-Link Blade setup.
  On 31/05/2013 at 11:52 AM, Paulie2256 said:
yeah. maybe someone with an fg can take a pic
That would be awesome!
I've found these pics in the Members Gallery and it clearly shows the FG LH and RH Engine Mount Brackets and the shape of the Sump.
The FG Sump might just work, or at the very least, require a lot less modification. Can someone confirm that these FG Engine Mount Brackets and in the same position on the BA/BF models? The Jag XK Mounts are on the Crossmember so I'd need to move the forward?
Thanks ScatterBrain, this is all good info for me.
I just trying to find some physical dimensions for the ZF 6HP26 now to see if it will fit my Jag Trans Tunnel. The Jag currently has a Borg Warner Type 12 3 Speed.
  • 2 weeks later...
  • Member For: 15y 3m 15d
Ive always fancied buying another xr6 turbo engine and sticking it in either a mark 1 escort or tvr tuscan over here.
