Falky100 Donating Members 305 Member For: 13y 3m 26d Gender: Male Posted 04/05/13 04:23 AM Share Posted 04/05/13 04:23 AM As the title says. I am getting a bad clunk at the moment which has just started. And for a while now I get a bad really fast knocking sound coming from the rear on takeoff when I let the clutch out (mainly when the car is under heavy load). It is quite bad with a box trailer on too. All the 3 bushes seem to be intact all I could find out of place under the rear was what you can see in the pics. The passenger side doesnt even have a plate on it and looks to be sunk back inside the bore. The drivers side plate is sticking out above the bore and the bush inside the bore also looks short. Sorry if the explanation doesnt make alot of sense or if the pics arnt the best. John. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 7m 9d Gender: Male Posted 04/05/13 05:27 AM Share Posted 04/05/13 05:27 AM Yes that's normal, check you driveshaft centre bearing Sent from my GT-I9505 using Tapatalk 2 1 Link to comment Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 13y 3m 26d Gender: Male Posted 04/05/13 05:28 AM Author Share Posted 04/05/13 05:28 AM Well... Found the problem. Link to comment Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 7m 14d Gender: Male Location: Hills District, NSW Posted 04/05/13 09:09 PM Share Posted 04/05/13 09:09 PM What are we looking at there? Link to comment Share on other sites More sharing options...
DD-XR-6T Member 134 Member For: 11y 11m 10d Gender: Male Location: Sydney/Canberra Posted 05/05/13 04:26 AM Share Posted 05/05/13 04:26 AM (edited) Missing bump stop? Wouldn't make much of a knocking sound if it is Edited 05/05/13 04:27 AM by DD-XR-6T Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 13d Gender: Male Location: Maryborough Qld Posted 05/05/13 08:30 AM Share Posted 05/05/13 08:30 AM dam! its the stabalise bar link, its punched through the arm buy the looks of it. new arm needed, I was lucky enough to get a brand new arm from a fg for my BA for 50 bucks lol seconhand they wanted 80 each....ebay your friend 1 Link to comment Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 13y 3m 26d Gender: Male Posted 06/05/13 10:03 PM Author Share Posted 06/05/13 10:03 PM The damn bushes clapped out and the nut pulled through the hole. Cracked all around the hole as you can see. So out with the mig and welded the cracks up the best I could in the space I had. Lucky the linkage is still ok. $40 for 2 new bushes + nuts from ford. Link to comment Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 13y 3m 26d Gender: Male Posted 06/05/13 10:05 PM Author Share Posted 06/05/13 10:05 PM (edited) The knocking sound is still there after I have been driving around with no sway bar on the rear. So you think it could be the driveshaft bearing that's causing the strange quick knock, Il check it out. Thanks bionic Edited 06/05/13 10:08 PM by Falky100 Link to comment Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 13y 3m 26d Gender: Male Posted 30/06/13 12:25 PM Author Share Posted 30/06/13 12:25 PM Hey bionic, finally got to my car this afternoon and checked the bearing. Well you are 100% correct. The rubber is completely shot. Do you have a rough price in this part? Or will a $65 one from ebay do the trick? http://bit.ly/1cDgtgX Cheers bionic. Link to comment Share on other sites More sharing options...
