andrewkerr Member 30 Member For: 12y 5m 13d Posted 02/05/13 08:52 AM Share Posted 02/05/13 08:52 AM I have a issue with my xr6 turbo sometimes when driving and it is building boost it feels like it is surging and looking at the boost gauge its going from 12 to 5 and sort of bounces in between (I thought it might be bleeding off boost ) but sometimes it will not do it and will just boost could this be due to the stock wastegate actuator.the car has had cams changed,1000cc injectors,walbro pump upgrade and upgraded valve springs and had a custom vcm tune .could it be that wastegate actuator and I am not sure if its been happening since I have changed to a 4 inch intake and plazmaman air box .any ideas what it could be or just take it and get someone to look at it just would be good to know what it could be so I can fix myself or at least tell someone what it is so I can save some time and $$$ diagnosing what it is Link to comment https://www.fordxr6turbo.com/forum/topic/84788-boost-surging/ Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 27d Gender: Male Location: @ my laptop Posted 02/05/13 09:08 AM Share Posted 02/05/13 09:08 AM you changed the airbox you need to change the tune as a starting point Link to comment https://www.fordxr6turbo.com/forum/topic/84788-boost-surging/#findComment-1385715 Share on other sites More sharing options...
andrewkerr Member 30 Member For: 12y 5m 13d Posted 02/05/13 10:00 AM Author Share Posted 02/05/13 10:00 AM would changing the airbox create alot of issues it used to have a growler on it before and changed from that I am new to the ford motor I did not think it would cause issues by changing it any help would be great just dont want to cause any issues to motor Link to comment https://www.fordxr6turbo.com/forum/topic/84788-boost-surging/#findComment-1385730 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 27d Gender: Male Location: @ my laptop Posted 02/05/13 10:15 AM Share Posted 02/05/13 10:15 AM changes to air flow on a tuned car will upset lots of things Link to comment https://www.fordxr6turbo.com/forum/topic/84788-boost-surging/#findComment-1385736 Share on other sites More sharing options...
andrewkerr Member 30 Member For: 12y 5m 13d Posted 02/05/13 10:20 AM Author Share Posted 02/05/13 10:20 AM ok no dramas will look into getting re tuned any idea what it would cost roughly to get a retune /new tune and would it be worth just getting a e85 tune this is just my weekend car Link to comment https://www.fordxr6turbo.com/forum/topic/84788-boost-surging/#findComment-1385739 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 27d Gender: Male Location: @ my laptop Posted 02/05/13 10:33 AM Share Posted 02/05/13 10:33 AM you need to talk to your tune about that, after we have tuned a car we just charge an hourly rate for the dyno, others charge a set price Link to comment https://www.fordxr6turbo.com/forum/topic/84788-boost-surging/#findComment-1385749 Share on other sites More sharing options...
