Brent310 Member 9 Member For: 15y 13d Gender: Male Posted 30/04/13 12:11 PM Share Posted 30/04/13 12:11 PM Here is a photographic guide how to change the interior light globes in your BF XR Falcon.Firstly, here is a link to where I got my globes from. Very fast postage and very nice product. http://www.ebay.com.au/itm/FORD-BA-BF-XT-XR6-XR8-TURBO-F6-INTERIOR-LIGHT-KIT-WHITE-/220755235240?pt=AU_Car_Parts_Accessories&hash=item33660991a8&_uhb=1#ht_5549wt_986-----------------------------------------------Reading Lights-----------------------------------------------Remove the housing by grabbing from one corner and pulling down until clips release.Remove housing and unclip power from the back.To remove lights, grab and rotate anticlockwise Remove globe by simply pulling straight out.Replace globes with your desired colour LEDsPlug the power back in and push the housing back into the roof until it clips in.Done.Before & After-----------------------------------------------Main Cabin Light-----------------------------------------------Start by removing the plastic cover.Now remove the globe, be careful, this is really tight so try and loosen the clips a little before pulling on the globe.Replace with the desired colour LED.Replace plastic cover.Before & After-----------------------------------------------Rear Seating Lights-----------------------------------------------Remove by using fingers or a flat head screw driver to open from the drivers end of the housing.Unplug from power for easy globe removalThese globes are bayonet type globes, so just push and rotate.Close up of the globe and housing.After completing all globe changes.Thanks guys 3 Link to comment https://www.fordxr6turbo.com/forum/topic/84778-guide-changing-interior-light-globes/ Share on other sites More sharing options...
Kos New Member 14 Member For: 16y 5m 27d Posted 06/02/15 07:55 AM Share Posted 06/02/15 07:55 AM This difference with the led's is very dramatic. Thanks for sharing Link to comment https://www.fordxr6turbo.com/forum/topic/84778-guide-changing-interior-light-globes/#findComment-1528280 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 8d Gender: Male Location: Adelaide Posted 06/02/15 08:17 AM Share Posted 06/02/15 08:17 AM Product parts numbers and where did you get them from. Looks good. Link to comment https://www.fordxr6turbo.com/forum/topic/84778-guide-changing-interior-light-globes/#findComment-1528289 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 10m 28d Gender: Male Location: Perth, Western Australia Posted 06/02/15 09:15 AM Share Posted 06/02/15 09:15 AM In my Tornado:Roof light - 42mmhttp://www.jaycar.com.au/productView.asp?ID=ZD0754Cat No: ZD0754LED Festoon Replacement Globe, 31mm, CANBus CompatibleA range of ultra-bright LED replacement "festoon" globes for car interior lights, which are fully compatible with modern "CANBus" systems that would otherwise give a globe failure warning when using an LED globe. Each globe features six ultra bright wide angle SMD LEDs, a non-polarity circuit (can fit the globe either way), and a CANBus circuit. There are three models to chose from, each working on 12VDC. Specifications: • Size: 42mm • Lumens: 150 • LED type: 6x5730SMD • Beam: 120º • Colour: WhitePrice: $12.95------------------------------------------------------------------Map light globes:T10 Wedge Replacement LED QUAD Globe (White)http://www.jaycar.com.au/productView.asp?ID=ZD0394Cat No: ZD0394Jazz up your automotive dashboard by replacing your indicator lighting with LEDs! Not only will they spruce up the look of your car, these are long life LEDs with low current consumption and total reliability. T5 and T10 sizes available to suit most applications.T10 Wedge 12VDC LED QUAD Globes White Cat No. ZD-0394 Red Cat No. ZD-0395 Blue Cat No. ZD-0396Price: $3.50 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84778-guide-changing-interior-light-globes/#findComment-1528303 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 10m 8d Gender: Male Location: Melbourne Posted 07/02/15 02:27 AM Share Posted 07/02/15 02:27 AM Thanks - good write up with pics. Often wondered how get at the globes. My rear passenger's been out since I bought it second-hand Link to comment https://www.fordxr6turbo.com/forum/topic/84778-guide-changing-interior-light-globes/#findComment-1528451 Share on other sites More sharing options...
