  • Member For: 14y 11m
Here is a photographic guide to help you change the colour of the Ignition Illuminator on your BF MkII XR6.
Here is a link to the globes I used from eBay. You need a T4 Wedge globe.
http://www.ebay.com.au/itm/130582917218?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Starting with the stock orange light you can see here...
Under the steering column you will see 3 screws, philips head. Remove all 3 of these.
Now the bottom and top halves will separate on the column and you can completely remove the bottom half.
You will need to unplug this power lead. (you can do this first or second)
Here is the screw that will release the housing so you can proceed to the next step. Again philips head.
Now you will be required to remove the following 4 clips to open up the housing. This is a bit tricky but it will help with a flat head screw driver.
Here is the T4 Wedge Globe, using a flat head, twist and remove.
Replace with your desired colour LED
Now return to the car and plug it back in, test. Once confirmed it is working, place the housing back over the ignition, screw back it in and replace the steering column cover, screw in and ensure the top half is in the correct place.
After
Cheers guys
  • Like 5
  • flame magnet
  • Member For: 16y 11m 15d
  • Member For: 17y 5m 7d
Fantastic pro quality photos and loved the write up mate! Big thanks, something I'll be doing for sure.
