Impellor Member 835 Member For: 14y 9m 6d Gender: Not Telling Posted 30/04/13 11:57 PM Share Posted 30/04/13 11:57 PM I agree wholeheartly with what you are saying Jet. But I believe that the neccessary/required turbulence is created by the runners that the manifold/plenum bolts to. Just look at a PW, Plaz, or Nizpro plenums on the whole, they are as smooth as a babies buttuck. So Mick that comment may have come a little soon. I feel that the goal here is to allow as much available air to the intake runners as possible. This can only be achieved by reducing friction. Now please don't get me wrong, this mod isn't going to compete with the increases that a good aftermarket plenum provides, but it will improve the factory items efficiency. Remember folks these are mass produced items. They are made to be cost effective, not to a standard. These are Fords not Ferrari's. Also I think that its important to highlight "Rednoses" comment about a mid 10 second car, and said car's tuner response. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385293 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 26d Gender: Male Location: Adelaide Posted 01/05/13 01:26 AM Share Posted 01/05/13 01:26 AM What about off boost inlet pulsing ?Could there actually be a reason for sizing to maintain positive and negative waves ?If it was a simple as making it bigger would they not of done it from the get go or do u think that at anything under 300rwkw would just kill the off boost efficiency and gain next to zip for the amount of flow ??Its all iffs and butts unless the proof pudding come out to play Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385318 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m Gender: Male Location: Far north queensland Posted 01/05/13 01:37 AM Share Posted 01/05/13 01:37 AM Go for it. Get hold of a manifold gasket(metal) mark with scribe. You will see how much can be taken off opening to inlet runners (3-4mm all round). You can open up the inlet from T/B considerably to match T/B opening, and improve airflow path to 1 and 6. CheersWhat cylinder is the most likely to lean out and melt first on B series barras? Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385324 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1d Gender: Male Location: Brisbane Posted 01/05/13 01:41 AM Share Posted 01/05/13 01:41 AM Unless you paint it black then it will make no fkn difference Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385327 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 26d Gender: Male Location: Adelaide Posted 01/05/13 01:46 AM Share Posted 01/05/13 01:46 AM Haha Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385330 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 30d Gender: Male Location: @ my laptop Posted 01/05/13 01:52 AM Share Posted 01/05/13 01:52 AM years ago, the top head guys would port and polish a cylinder heads and inlet manifolds runners, it was then found that a little turbulence was good on the inlet side as it kept the fuel and air mixed together rather than seperating, with EFI cars we do not really have these issues but the last few years it has been found that a textured surface can in certain applications creat a cushion of air which keeps the air speed up of any passing air, many items these days that are trying to cheat the air will use a dimpled surface rather than the previously smooth surface, but as Jet has said unless flow testing has been carried out, we are all just guessing 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385332 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 7m 3d Gender: Male Location: Perth Posted 01/05/13 02:40 AM Share Posted 01/05/13 02:40 AM ^golf ball 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385341 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 30d Gender: Male Location: @ my laptop Posted 01/05/13 02:47 AM Share Posted 01/05/13 02:47 AM Golf ball is the classic example and I was going to mention it but I thought them some might argue that it is about lift rather than airflow, but it is based around the same principal Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385344 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 7m 3d Gender: Male Location: Perth Posted 01/05/13 02:49 AM Share Posted 01/05/13 02:49 AM So I Should install a golf ball in each manifold runner? 2 Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385345 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 6d Gender: Not Telling Posted 01/05/13 02:51 AM Share Posted 01/05/13 02:51 AM The surface in the plenum is certainly not dimpled, actually the opposite. Im sticking to the theory "Path of least resistance". Certainly some good comments and idea's all the same. Mick I have also read that by providing a polished intake or port is detrimental. But I don't believe that the plenums role is to create turbulence. This occurs within the runners, this is exactly why bolt on plenums produce results. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/page/3/#findComment-1385348 Share on other sites More sharing options...
