  • EPC Member
  • Member For: 16y 6m 2d
Just wondering if this mod is worth doing if you are chasing max power out of a stock looking setup, iv read some posts about it but cant find any sort of results or gains. Il post a pic as an example
https://www.fordxr6turbo.com/forum/topic/84762-ported-babf-inlet-manifold/
  • flame magnet
  • Member For: 17y 20d
contact impellor...... just for lols if nothing else...
  • RNS10S
  • Member For: 18y 9m 20d
Have heard this being done to a BA that went on to run a mid 10, not sure how much was due to the
plennum but the tuner seems to think it made a difference.
Edited by rednose
  • Member For: 14y 10m 16d
  • Gender: Not Telling
Go for it. Get hold of a manifold gasket(metal) mark with scribe. You will see how much can be taken off opening to inlet runners (3-4mm all round). You can open up the inlet from T/B considerably to match T/B opening, and improve airflow path to 1 and 6. Contrary to the doubters beliefs you can do alot to these manifolds to assist flow.Im not aware of anyone doing a direct comparision, due o the major fark around and time required to chop and change. But from a theroretic perspective to open it up and smooth will increase airflow, by reducing turbulence. Less turbulence = less friction = increased flow efficiency. Also if you go ahead, don't forget to add a catch can.
Cheers
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 5d
Unless u have ever done any flow testing ( dont think u have ) u may actually fark up the hole design characteristics of the manifold
And gain nothing but a placebo effect
Trust me when I actually went and learnt about flow testing items and majorly manifolds and heads the things u dont understand (average joe ) is the fact that alot of "imperfections" are actually purposeful "lips" /"dips" that engineers have put into the casting for tumble or swirl or velocity
Unless u have genuine before and after stats u may royally phuck up an item and its not as easy as u think
The newer the car the more it has been engineered .... Have a think about it
  • flame magnet
that doesnt sound right aaron- I heard the bigger everything the better....
trana with stractors....
  • Moderating Team
  • Member For: 22y 4m 5d
Mcf*cken lol @ trana with scractors
Heard the same, engineers build imperfections into manifolds to improve velocity.
I learnt that bigger aint always better when building my XC engine. my alloy heads had heaps of meat left, engine builder said no way, I aint touching them.
