Is Car Safe To Drive With Check Engine Light On? + Procedure To Change
  • Member For: 18y 8m 26d
As determined in a post below I am having coil problems with my BFII XR6T.
I am away on holidays in the Snowys and I wonder if I need to waste a day with the local ford dealer swapping out the coils or whether the car will be safe to drive back to Sydney?
During a misfire today the check engine light came on, and now stays on while driving.
I am hoping that the answer will be - its fine to drive back to Sydney.
If it is fine to drive does anyone have a procedure / extract from the workshop manual, for changing the coils?
Thanks John
Edited by Jonno
  • Bronze Donating Members
  • Member For: 13y 9m 7d
If you drive it normally youl be fine, providing the engine light is missfire related (codes p0301-p0306 plus random missfire code), to get to the coils you only need to remove the crossover and coil cover, it is VERY easy and youd have to be a neanderthal to f*ck it up. Have a go u might learn something :)
  • Member For: 16y 5m 12d
Coils and new 8mm plugs before tune
Edited by Paulie2256
  • Member For: 14y 6m 23d
Going on your previous thread, I would be looking at plugs, and make sure they are gapped at .8mm, not the 1.1 on the box.
I really cant believe that these engines have so much coil problems, or are the symptoms being missdiagnosed?
And, what are 8mm plugs? :dontknow:
