Worpor Member 467 Member For: 20y 11m 16d Location: Perth Posted 12/03/04 12:05 AM Share Posted 12/03/04 12:05 AM I would be interested. But it looks to late now. Can any one please give me there ph# as Ive tried white pages and call conect with no luck. Thanks Link to comment Share on other sites More sharing options...
Trumpy What's happening? Lifetime Members 1,605 Member For: 22y 1m 27d Gender: Male Location: Steel City, NSW Posted 12/03/04 12:07 AM Share Posted 12/03/04 12:07 AM GAUGE WORKS AUSTRALIA Unit 3/ 6 Shepherd Crt North Geelong 3215 (03) 5277 9296 Fax (03) 5277 9487 Courtesy of XR6na in the original thread under the link at the top of this page. Worpor,It was on the second page of the thread. Good luck Link to comment Share on other sites More sharing options...
JB Forum Superhero Donating Members 3,109 Member For: 21y 2m 4d Location: Eastern Suburbs of Mexico Posted 18/03/04 05:12 AM Share Posted 18/03/04 05:12 AM Trumpy, YCL or Basher TSV or any one else, I need some advice. got my guage and fitted it (record time I think, 20mins ) normally I am not that good at this sort of stuff but it was easy.However I seem to have alot of noise from the engine bay. More louder turbo noise than anything, it sounds like the insulation has been removed it is quite loud. When it's not on boost it's quiet, it's just when it comes on the turbo whoooshing sound is very loud (like I am running big boost 15psi). The guage is going to about 7 psi, and flickering badly.I have spoken to luke he is going to try and fix the flickering, but he does not know about the noise. Had anyone else noticed their car now being louder?I have reapplied teflon tape to the T peice but that has made no difference. Besides that I love the guage it's fantastic and looks straight out of the factory. Can anyone offer any advice or suggestions? Link to comment Share on other sites More sharing options...
Zeke zeke Member 792 Member For: 21y 7m 10d Location: Adelaide Posted 18/03/04 07:13 AM Share Posted 18/03/04 07:13 AM Hi JBWell one of two people in this thread have mentioned a slight increase in engine noise, but I'm adamant that I haven't had this.Suggestions:1. Make sure the rubber grommet went back into place properly. If it's really loud, the grommet sliipping out of the hole is the only thing I could imagine would cause that.2 Make sure that tube is a tight fit in the hole you made in the grommet - if not, apply Vik's mastertool (silicone) (hi -temp black)3 Make sure the tube isn't under undue tension.4 If all else fails, look for unrelated, coincidental cause.Mine wavers a tiny bit on the boost side only. Rock steady on the vacuum side. Really doesn't bother me, but I'm a bit curious about the reason.Cheerszeke Link to comment Share on other sites More sharing options...
JB Forum Superhero Donating Members 3,109 Member For: 21y 2m 4d Location: Eastern Suburbs of Mexico Posted 18/03/04 07:29 AM Share Posted 18/03/04 07:29 AM Hi JBWell one of two people in this thread have mentioned a slight increase in engine noise, but I'm adamant that I haven't had this.Suggestions:1. Make sure the rubber grommet went back into place properly. If it's really loud, the grommet sliipping out of the hole is the only thing I could imagine would cause that.2 Make sure that tube is a tight fit in the hole you made in the grommet - if not, apply Vik's mastertool (silicone) (hi -temp black)3 Make sure the tube isn't under undue tension.4 If all else fails, look for unrelated, coincidental cause.Mine wavers a tiny bit on the boost side only. Rock steady on the vacuum side. Really doesn't bother me, but I'm a bit curious about the reason.Cheerszeke Yeah will check that out Zeke, even though the only thing it may be out of your suggestions are undue pressure on the hose.Mine is a manual, hence I put the tube straight through the grommet in between the two pipes, it just went straight through.May be a silicone job! I would love to see if any of the other guys have had the same prob Link to comment Share on other sites More sharing options...
Guest Basher_tsv Guests Posted 18/03/04 11:05 PM Share Posted 18/03/04 11:05 PM No serious increase in noise on mine - however when giving it the boot I can hear the hiss more than factory (but that is all good).Sits on about 6psi on boost with not much flicker at all.Hope you sort it out - it must be noticeably louder becaus I think it is fine. Cheers, B. Link to comment Share on other sites More sharing options...
