  • Member For: 12y 5d
Yeah it only does it in 3 gear 3 half thousand revs onwards gets worse in 5th I took intake pipe off and there was a little drop of oil in turbo, turbo fins look fine. I also noticed I have a hole in manifold.. Does anyone know where I start to look for a fix
  • Member For: 12y 9m 8d
mine seems to have a massive air lek noise, but still holds 6psi boost...under heavey aceleration
also if the inline filter was clogged wouldnt you get a very very bad noise? as im guessing these turbos would f*ck up straight away
when should I check my earls inline filter? its been on for about 5 000k
