  • Spooling Member
  • Member For: 13y 6m 3d
Gonna have to change the bushes eventually anyway as the stock ones are poo. May as well eliminate the possibility
  • Bronze Donating Members
  • Member For: 12y 4m 15d
Yeah see the the thing is the faster I go the less I notice it because im not making enough power to load up the driveline once I click fourth gear. Cruising on 200kmh (on race track)car is perfect .
Yeah for sure it was on the to do list anyway .
Because I know Chris has made shafts for two other cars that I know of with good results it makes sense to upgrade the standard bushes , because even though they are not split they are very sloppy.
  • Idiot Member
  • Member For: 15y 4m 19d
Sent pm LU82. Check your pinion yoke bolts. I was running cut down stock bolts that I cut mismatched. Had slight vibes. Now running allen key headed 12.9 grade bolts in proper length needed. No vibes
Thanks for the info I will call Chris next week and run it by him.
Hopefully its just a process of elimination Chris has been great to deal with so I'm sure something will work out
  • 2 weeks later...
Bit of an update.
Picked my car up from Gibson driveshafts today, Chris had no luck sorting out the vibration so he went back to the standard CV joint and the vibration has gone away. Not really what I was hoping for but should be ok for my current power level.
  • 4 weeks later...
Is the vibration while driving at a certain speed or only under acceleration?
What was upgraded on your tailshaft?
My vibration was only under acceleration and changing the height of the centre bearing did not fix the vibration . My car is a sedan not sure if there is much difference with a ute.
My cv joints were changed to uni joints and the only way to eliminate the vibration was to go back to the standard cv joint where it bolts up to the diff.
The only reason we can come up with as to why the gibson 1000hp tailshaft did not work in my car is something is slightly out of alignment in my driveline because the same tailshaft has been fitted to a number or cars with success with no vibration.
Edited by LU82
