DD-XR-6T Member 134 Member For: 11y 10m 6d Gender: Male Location: Sydney/Canberra Posted 15/04/13 11:48 AM Share Posted 15/04/13 11:48 AM The thing is your ute might have a tune in it unbeknown to you. It just wont take 91 under load.^ this in addition to one or many of the following;Dirty Throttle body,dirty injectorsdirty fuel filerfuel pump on its way outboost solenoid could be screwyturbo bolts loose - can cause all of this due to lack of boost and overcompensating with fuellack of oil pressurebasically all the overlooked things in your regular servicing schedule by poor mechanics can result to the computer over-correcting everything as it is all computer controlled.best job you can do is go over all of these yourself as it is all cheap and easy stuff to do in the comfort of your own shed, and then when you go to the mechanic you can rule all of these simple things out and not get charges out the arse for them. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 14d Gender: Male Location: Christchurch, New Zealand Posted 16/04/13 03:38 AM Share Posted 16/04/13 03:38 AM Could even be valve springs but its all guessing. Start with easy stuff and make sure no leaks missing bolts. And as stated could have a tune for all you know.As for 91 my understanding was only if you cant get anything else and dont boost it as you should run a min of 95 for giving the thing abuse. 1 Link to comment Share on other sites More sharing options...
