Loose Flywheel Bolts
a2z
  • Member For: 15y 9m 7d
I have gone to a bit of a frankenstein setup but it seems to work ok.
Ditched the ARP bolts and gone to 12.9 socket cap bolts with Atomic washers
3x 11mm dowels, welded to the flywheel.
Bolts tightened to 90ft/lbs
Made up a plate with 6 holes in it which fits over the bolts and then welded each of the bolts to the plate.
Next crank I put in it, I will be looking at running 12 bolts.
  • New Member
  • Member For: 7y 7m 19d
Yeah no worries. If the welded flywheel bolts are still all good what could be causing the damage to the clutch then?I've tryd 2 ace clutchs plus 1 other brand which I can't remember at moment & still has the same problem.When there fitted they feel fine but after being on the dyno & driven for a few weeks it develops a shutter & is hard to get into 1st & reverse.Don't really want to go & weld the bolts in on the new set up untill I know whats causing it & fix it.
  • Dropping a turd
  • Member For: 17y 3m 19d
12.9 don't like to be welded with no preheat. May hold.
The hardness of 12.9 also makes them subseptable to hydrogen embrittlement
what you have done sounds good in the theory .  But I would say they will crack at the welds.
Edited by arronm
I was skeptical as I thought you could get nothing better than ARP, but 4 sets of ARP later and the 12.9s are holding on a lot better.
I have broken one bolt but I don't think there is much I can do with the brinelling on the crank and the lack of surface to mount to.
The crank will have to come out and be repaired at some stage but until then I'm happy pulling the box out every couple of months!
