Loose Flywheel Bolts
a2z
  • Member For: 15y 8m 16d
After removing the gearbox on my 2010 fg f6 at christmas and finding the six bolts half way out I thought I would just tighten them and all would be fine..... well for 4 months only.
Yesterday I heard the same knocking noise again.
Before just pulling out the gearbox I thought I'd ask around about a better fix.
Has anyone had this problem before or knows a fix?
Would a better loctite be available or more torque on the bolts or would helicoils be needed????
Any suggestions would be awesome.
  • Member For: 13y 10m 29d
The holes become elongated when they come loose and will keep coming loose.
When you say flywheel I assume its manual? Mostly happens to the flex plates on the autos, I've not heard of a manual having the problem. Will need a new one either way I reckon
Edited by knoles
Yeah mate its manual. So basically because the holes in the fly wheel become destorted there will always be a play and no ammount of tourqe or or fitting procedure wouldl be a permanent fix?
What a fricken pain in arse. I dont need a new clutch yet and the gear box has to be pulled out again in as little as 4 months. Knowing my luck the clutch will have an epic fail as soon as I put the box back in.
Any sugestions as to which is a better fly wheel?
  • Member For: 21y 10m 15d
This is what I do with the auto. Same with the manual. My opinion is just not enough bolts on the crank post-822-0-67597200-1365583415_thumb.jpg. But the lock tabs stop the bolts undoing.
I had a Expensive Daewoo 202 that would spit the crank off. Putting an extra 4 10mm allen key headed bolts inbetween the existing bolts solved that. Then I went with an alluminium flywheel with standard bolts and never budged. I think ally helps the harmonics.
So my utes only got 23000km on it and only done 9k of those with 380rwkw. The fly wheel and clutch are still in great condition. Do you think I should wait on replacing the fly wheel and go with tabs until I need to replace the clutch and go a new fly wheel then?
Where can I get some tabs from?
I made it all myself but copied this method from "grade 8" fasteners. I used the original bolts but you need to get a machinist to cut a groove in the middle of the bolt and get the right size circlip. I think is 20mm from memory. I am quite sure I have a set of ally tabs that I could send you to try and maybe a sample circlip.
But with anything with engine building you need to have attention to detail for it to work as intended.
Alternatively you could check Grade 8 to see if there is anything they have. I have used their products before but the crank bolts they supplied were fully threaded to the head which I deemed not the best. They need to have the shank to have a tight as possible fit. You need to torque it right with a good torque wrench. I would even undo and retighten a couple of times as I feel more comfortable that whatever little stretch that is in the bolt is taken out.
I dont know if I would use locktite. I am undecided on the benefits of this as I have used it enough times and the standard bolts still came loose on my turbo 202 torana.
