MY ROD GOT OUT Member 434 Member For: 14y 8m 15d Posted 08/04/13 10:26 PM Share Posted 08/04/13 10:26 PM hey peoples, car has developed a shudder on take off when driven for the first time in the morning etc (6sp manual), once warm the shudder goes away. im assuming its from the clutch and may need new fluid and bleeding?? I decided to hop under car and inspect for any leaks etc but found none and clutch reservoir is full but fluid looks a bit yucky. I also had a look under while car was running and at the gear box there is air coming out of a couple of spots.... im guessing its normal but have attached pics of the spots to make sure.cheers Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/ Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m 15d Posted 09/04/13 12:27 PM Author Share Posted 09/04/13 12:27 PM No one?? Not even a response to the cheers.....Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379125 Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 7m 3d Gender: Male Location: sydney Posted 09/04/13 12:42 PM Share Posted 09/04/13 12:42 PM Hi Finney. How are you. Mine did the same at the moment I'm still working on it. I'm no expert but most people on this forum think I am. Diff bushes or rear wheel hub and or tail shaft centre bearing. I put my money on tailshaft centre bearing. Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379129 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m 15d Posted 09/04/13 08:55 PM Author Share Posted 09/04/13 08:55 PM So tailshaft bearing causes the shudder when cold and then goes away when warm? What about those spots I pointed to where air is coming out... Normal? Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379176 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 26d Gender: Male Location: Perth Posted 10/04/13 01:30 AM Share Posted 10/04/13 01:30 AM Shudder will be from the clutch. Likely cause by buildup on the flywheel or pressure plate/or warpage of the flywheel or pressure plate that evens out a touch when warm.The air holes on the gearbox are normal. Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379263 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 3m 18d Gender: Male Location: Sydney Posted 10/04/13 01:48 AM Share Posted 10/04/13 01:48 AM Big ups on the cheers though Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379265 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 18d Gender: Male Location: Adelaide Posted 10/04/13 02:17 AM Share Posted 10/04/13 02:17 AM Cheers to the cheers 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379275 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 7m 21d Gender: Male Posted 10/04/13 03:11 AM Share Posted 10/04/13 03:11 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379295 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 28d Gender: Male Location: SE Melbourne Posted 10/04/13 03:29 AM Share Posted 10/04/13 03:29 AM Fluid will be dirty. Even after you flush it and drive it down the road and back its dirty again. Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379303 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m 15d Posted 10/04/13 03:37 AM Author Share Posted 10/04/13 03:37 AM On 10/04/2013 at 1:30 AM, Ralph Wiggum said: Shudder will be from the clutch. Likely cause by buildup on the flywheel or pressure plate/or warpage of the flywheel or pressure plate that evens out a touch when warm.The air holes on the gearbox are normal.Anyway to fix??And cheers for the cheers's everyoneAnd paulie I haven't changed fluid in it for approx 2 years... Link to comment https://www.fordxr6turbo.com/forum/topic/84560-is-this-normal/#findComment-1379306 Share on other sites More sharing options...
