xhxrsix Member 174 Member For: 18y 5m 5d Gender: Male Location: Melbourne Posted 08/07/13 02:41 PM Share Posted 08/07/13 02:41 PM One would assume the 30mm is standard and 35mm for the turbo/v8 models? I did one a while back on my BA and never needed to do anything fancy... it had a uni joint type though. If the tailshafts are busting is it the type with the old uni joint or the 'crimped' style that's worse? Link to comment https://www.fordxr6turbo.com/forum/topic/84522-fg-tailshaft-centre-bearingcan-you-buy-one/page/4/#findComment-1405119 Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 13y 5m 1d Gender: Male Posted 08/07/13 10:20 PM Share Posted 08/07/13 10:20 PM On 08/07/2013 at 2:41 PM, xhxrsix said: One would assume the 30mm is standard and 35mm for the turbo/v8 models? I did one a while back on my BA and never needed to do anything fancy... it had a uni joint type though. If the tailshafts are busting is it the type with the old uni joint or the 'crimped' style that's worse?When I first investigated a replacemet bearing I assumed 35 mm for turbo/v8 aswell. But that doesnt seem to be the case. Link to comment https://www.fordxr6turbo.com/forum/topic/84522-fg-tailshaft-centre-bearingcan-you-buy-one/page/4/#findComment-1405147 Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 13y 5m 1d Gender: Male Posted 10/07/13 11:35 PM Share Posted 10/07/13 11:35 PM Wow. When I was getting tyres put on yesterday, the mechanic at Jax tyres quoted me $375 to replace the bearing. $240 for the part plus an hour or so labour. Link to comment https://www.fordxr6turbo.com/forum/topic/84522-fg-tailshaft-centre-bearingcan-you-buy-one/page/4/#findComment-1405625 Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 13y 5m 1d Gender: Male Posted 12/07/13 12:06 AM Share Posted 12/07/13 12:06 AM Burson driveshaft services in edgeworth. $275 out the door. Includes new uni, and bush. Now to book it in! Link to comment https://www.fordxr6turbo.com/forum/topic/84522-fg-tailshaft-centre-bearingcan-you-buy-one/page/4/#findComment-1405962 Share on other sites More sharing options...
RSWEPN Donating Member Donating Members 187 Member For: 18y 5m 18d Gender: Male Location: Sydney Posted 13/07/13 04:28 PM Share Posted 13/07/13 04:28 PM Speak to Propeller Shaft Services. They recently sorted out an issue on a FG tailshaft that 2 other tailshaft shops couldnt.Address: 14 Ilma St, Bankstown NSW 2200Phone:(02) 9771 2575 Link to comment https://www.fordxr6turbo.com/forum/topic/84522-fg-tailshaft-centre-bearingcan-you-buy-one/page/4/#findComment-1406478 Share on other sites More sharing options...
was270 Member 26 Member For: 12y 7m 14d Gender: Male Location: Belconnen ACT Posted 10/08/13 09:56 PM Share Posted 10/08/13 09:56 PM It seems there are quite a few variations of tailshafts fitted to FG's. My ute has (or had) the centre bearing and CV setup. When the the centre bearing let go it destroyed the centre CV too. The Centre Bearing was replaced but after driving it home the CV was stuffed as well. I had a new shaft made that has a removable uni and centre bearing that can be replaced.I wouldn't recommend using the place I went as my car has been back about four times for warranty related issues and is now only getting fixed after legal advice was sought. But if you can get someone to build you a shaft that has a removable uni and bearing its definitely the way to go. Link to comment https://www.fordxr6turbo.com/forum/topic/84522-fg-tailshaft-centre-bearingcan-you-buy-one/page/4/#findComment-1414721 Share on other sites More sharing options...
