  • Just a large member member
  • Member For: 16y 6m 1d
Crimped you can see them. Not a press fit.
  • Member For: 16y 4m 9d
Keep an eye out for a second hand shaft I bought a bf f6 one off eBay posted for $150 so I can send it off to get built
I might have found some light at the end of the tunnel..Found a guy in sydney who reckons if I take him my tailshaft he will supply and fit centre bearing for $110...I'll keep you all informed and post his details if he can and does it..This place is a propeller shaft place,he suggest I also balance my tailshaft for an extra $180..Should I or should I not get it balanced...Ford balances the shaft on the car that why we have those plastic weights on the back of the diff pinion..Which makes my think that the output shaft and diff pinion are included when balanced,so if he balance the tailshaft only I have every chance of having a vibration problem..
This could become the most valuable post I"ve posted on here in my time..LOL
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 17d
Lol bit true rooster don't bother getting it balanced until its on the car and then only if it gives u grief
Moore goats in this thread as well
  • Member For: 16y 16d
The centre bearing on the FG is a pressed fit and you have to replace the uni and the centre bearing at the same time. This is what I was told by ford, the centre bearing and uni are $600 ish from memory, just fro the part. Hence I went with an upgraded tails haft with a replaceable centre bearing from a F150.
  • Member For: 15y 5m 23d
Bearing has to be a pressed fit, it has a parallel bore, if it wasn't a press/shrink fit it would move.
Being a double row ball bearing it would have a very light interference fit, should go off/on with only a little bit of heat.
Rootster, keep the old bearing, cut it in half and send me pics, I'll tell you if you should have balanced your tailshaft
  • 2 months later...
  • Member For: 13y 5m 7d
SHP, needing some help. Obviously by the pics I need a new bearing too. My car is a BF. and im unsure as to weather I need a 30 or 35mm bearing and whether it is a press fit etc. Just wondering whether you can give any info on this for me.
Also I think mines a uni joint. In the pics you can see a sir-clip where when removed the pin will just "fall out".
