Camshaft Duration
HSV ETR
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 5m 9d
Interesting topic but I think op needs to be more specific in what he wants because std cams and std VCT is more than sufficient
Just dial in more overlap VCT FTW
  • Member For: 12y 3m 18d
well im only getting cams solely because I want it to be lumpy at idle (on the edge of stalling lol) and I know that referrs to lobe centres being further apart but if I were to get cams I would want something with high duration and something around a 500ish lift for that little bit of extra power
Buy some atomic stage 4+ cams and solid sprockets and wam bam thank you mam for a pig of a drive and shocker on fuel and massive losses in torque down low
I love u
I thought cams to suit a turbo are designed to give u good down low and midrange?? I was considering atomic stage 4 but I was comparing them to the crow 591 cams and crow seem to have a slighty bigger duration and wider (113) lobe centers which would give it a lumpier idle. I couldnt care how thirsty it is it only gets driven on weekends
nooo I love u more
Crow cams are usually stated at total duration not actual measured duration ( less 50tho ) we have VCT so we have brilliant down low clean idle with small overlap to keep emitions in check yet can move 250o within 0.5 of a second to have massive overlap and big torque spread
Big cams do nothing but come into there own on huge hp situations 1000hp+
Why would I sacrifice all of that driveability for a low vacuume situation with crap brakes at crawling speeds and shocking torque either down low or up top ( u cant have both ) but u can with VCT
Big cams and vct can happen but u wont get the effects your after ( way cool lump man )
  • Member For: 13y 9m 21d
Actually I just checked the atomic site. The stage 4 cams are duophased now as well. Also looking at the specs, the 4+ will be a bit lumpy. Even with the staggered valve timing. The 4's could almost sound stock.
Pretty sure a mate down here has 4's in his turbo ute. I'll try get a video.
Edited by Mr_4.0
