p4c3y Member 5 Member For: 14y Gender: Male Location: melbourne Posted 31/03/13 05:35 AM Share Posted 31/03/13 05:35 AM G'day All. Just purchased my first fg after owning 2 ba xr6t's. My concern is the turbo makes an annoying howling noise off boost. howling gets louder the more revs you go (before boost) and howls down like a police siren when off the throttle. I havent really investigated much yet though when the turbo is shut off (car turned off) it spools down quietly like normal.What things should I check? I. eg, splits in hoses. loose hoses!? a tiny coyote in that pod looking thing at the turbo from throttle!I did notice this sound on my first ba when it was cold only. its got stat 3 month warranty but id like to sus it out before I take it in to get an lsd fitted next week incase I need to spend cash on it! Link to comment https://www.fordxr6turbo.com/forum/topic/84452-g6et-turbo-howling-sound/ Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 4d Gender: Male Location: Vic Posted 31/03/13 05:51 AM Share Posted 31/03/13 05:51 AM Check for torn pipes first. Link to comment https://www.fordxr6turbo.com/forum/topic/84452-g6et-turbo-howling-sound/#findComment-1376144 Share on other sites More sharing options...
p4c3y Member 5 Member For: 14y Gender: Male Location: melbourne Posted 31/03/13 06:48 AM Author Share Posted 31/03/13 06:48 AM On 31/03/2013 at 5:51 AM, Henz said: Check for torn pipes first.I had a quick look at the piping clamps and what not. though Ill go ever it tommorow morning hose by hose see what that outcome brings me. bloody annoying sound it is. Link to comment https://www.fordxr6turbo.com/forum/topic/84452-g6et-turbo-howling-sound/#findComment-1376155 Share on other sites More sharing options...
Boosted1 Member 346 Member For: 16y 5m Posted 31/03/13 09:26 AM Share Posted 31/03/13 09:26 AM if could be head droop on the turbo from hot shut downs. it makes a howling sound mostly on spool past the transition from vac to boost pressure Link to comment https://www.fordxr6turbo.com/forum/topic/84452-g6et-turbo-howling-sound/#findComment-1376192 Share on other sites More sharing options...
p4c3y Member 5 Member For: 14y Gender: Male Location: melbourne Posted 01/04/13 07:11 AM Author Share Posted 01/04/13 07:11 AM I had a bit of a better look this morning with intake pipe off turbo. turbo shaft is in perfect condition spins freely and no movement in shaft. check over hoses and piping. still same thing. Basicly loud as Fek spooling up. But once on boost sounds like a normal fg (kinda supercharged) Link to comment https://www.fordxr6turbo.com/forum/topic/84452-g6et-turbo-howling-sound/#findComment-1376395 Share on other sites More sharing options...
Boosted1 Member 346 Member For: 16y 5m Posted 01/04/13 07:34 AM Share Posted 01/04/13 07:34 AM def sounds like head droop, ive seen a few turbos develope it. you cant tell by looking at it as its the turbine wheel that has drooped slightly off its ballanced axis. Link to comment https://www.fordxr6turbo.com/forum/topic/84452-g6et-turbo-howling-sound/#findComment-1376401 Share on other sites More sharing options...
g6e-psi Member 46 Member For: 13y 6m 3d Gender: Male Location: melbourne Posted 01/04/13 07:26 PM Share Posted 01/04/13 07:26 PM check the manifold gasket and the turbo flange gasket 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84452-g6et-turbo-howling-sound/#findComment-1376544 Share on other sites More sharing options...
