  • Member For: 17y 2m 1d
Like you guys would know.
You need
Port and polished inlet and exhaust manifolds.
Red heat shields.
Billet oil caps.
A can of black hi temp paint.
Access to wiki.
  • Like 3
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 20d
  • Member For: 19y 10m 13d
  On 29/03/2013 at 8:14 AM, AGENT ORANGE said:
hey guys jus wondering if some people could giv mi some answers or ideas on wat needs to be changed to run a gt3788 please thank you,im making 400rwkw now but the power bug has bitten and I want more lol
I'm gathering you can get this turbo cheap.....
The stock turbine is a 68mm whereas a 3788 has a 72.5mm iirc. Meaning you cant use the stock 1.06 A/R T3 exhaust turbine housing. You would need an aftermarket manifold, dump pipe, oil/water lines, intake etc etc. if you were to go to this much trouble there are more suitable turbo's available.
If this hasn't put you off then the fact that a GTX3582r that will fit the stock turbine housing and manifold actually flows MORE than a GT3788r. Stick with the latest technology available when it comes to turbocharging :)
  • Like 2
  • Member For: 16y 5m 27d
all bs aside you could run a hta3794r in a stock 1.06 housing. the rear housing just has to be profiled to suit the slightly larger turbine wheel, cost round 300 to 400 dollars. doesnt have rediculous lag, full boost by round 3300 to 3500 (20psi)
but if I was you the gtx is hard beat for price and results
Edited by Boosted1
True, and thing to note with the above is that HTA's use a billet compressor and a reliable Garrett core and exhaust turbine. Big flow for a compact T3 footprint.....
  • F6 Phoon ----- MISH!!
  • Member For: 18y 3m
ok thanks guys,an as was mentioned before the only reason was asking bout this turbo bcoz it was dirt cheap,but yes I agree with most of yous on here bout the gtx 3582 they r a good turbo,
or am I better off jus goin a .70 comp housing?
If its a b series turbo already just do the .7 if anything.
If the turbo has a number of KM's on it change to a GTX3582r or HTA3586r if you want a bit more again.
turbo only has 85k on it,im looking for the .70 housing but never realised how hard to get around here,but wat my main thought was if I get a bigger turbo I could then use it on my built motor weneva the time comes lol :blind:
