Jmr84 Member 31 Member For: 12y 4m 4d Gender: Male Location: Ipswich, queensland Posted 28/03/13 09:26 PM Share Posted 28/03/13 09:26 PM Hey guys new to fords but think I got inboard with a good one. Have a bf XR6T tray back ute with a bit of work running 285rwkw with a zf box. Anyway to the point. At lights in drive I sometimes get this bad vibration through the whole ute but if I bump it into neutral it goes away. Sometimes there is a little vibration sometimes alot. I was concerned about this and seen talk on the zf milkshake so I took the supply line off the cooler to check oil. The oil is still ok, when I have a spare thousand dollars :-/ ill do a change on it. But any ideas on what might be causing this vibration? Converter cavitation, engine mounts possibly? Any ideas would be good. Cheers. Link to comment Share on other sites More sharing options...
Jmr84 Member 31 Member For: 12y 4m 4d Gender: Male Location: Ipswich, queensland Posted 28/03/13 09:27 PM Author Share Posted 28/03/13 09:27 PM * on board Link to comment Share on other sites More sharing options...
GSP07R Member 248 Member For: 12y 1m 26d Gender: Male Location: Western Syd Posted 28/03/13 09:29 PM Share Posted 28/03/13 09:29 PM Could be mounts, knocking, spark plugs. When is it due for a service? Link to comment Share on other sites More sharing options...
Jmr84 Member 31 Member For: 12y 4m 4d Gender: Male Location: Ipswich, queensland Posted 28/03/13 09:41 PM Author Share Posted 28/03/13 09:41 PM I did a fluid service in engine bay couple of weeks back. Only run it on 98. Ill check the plugs over this weekend. Was just concerned it might have something to do with the zf. Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 22d Gender: Male Location: Gold Coast Posted 28/03/13 10:19 PM Share Posted 28/03/13 10:19 PM Mate I had the ZF serviced yesterday and pulled up at a drive through on the way home then clunk brrrrrr. Turned out to be nothing wrong with the trans but, one of the blades on the themo fan had fractured on the seam join and started lunching itself on the shroud. The vibration through the car was horribile. I disconnected the cable and drove it home (hwy only). Got a complete new assembly late yesterday and fitted - all good. From what you've described, I'd be taking a look at that. Link to comment Share on other sites More sharing options...
Stevecoutts Member 3 Member For: 12y 10d Gender: Male Location: Sydney NSW Posted 29/03/13 12:43 AM Share Posted 29/03/13 12:43 AM I had the same issue on my 03 BA XR6T and just today pulled it apart and found that the exhaust manifold bolts under the heat shield were very loose (one was almost completely undone) anyway, I tighten all the bolts and the problem has gone completely. Link to comment Share on other sites More sharing options...
old_mate Member 767 Member For: 19y 20d Gender: Male Location: Brisbane Posted 30/03/13 10:02 AM Share Posted 30/03/13 10:02 AM flex plate? Link to comment Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 5m 20d Gender: Female Location: SA Posted 30/03/13 10:14 AM Share Posted 30/03/13 10:14 AM Had same issue... ended up being engine mount...Ona side note... check your golve box... could have left your *beep* switched on 1 Link to comment Share on other sites More sharing options...
Jmr84 Member 31 Member For: 12y 4m 4d Gender: Male Location: Ipswich, queensland Posted 02/04/13 12:24 PM Author Share Posted 02/04/13 12:24 PM Thanks guys ill have a thorough look over this weekend see if I can get rid of this vibration. Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 10d Gender: Male Location: Maryborough Qld Posted 02/04/13 03:18 PM Share Posted 02/04/13 03:18 PM yeah I have same prob, its my drivers side engin mount, compleatly sagged and disinergrating. does your engin sit on a lean??? if so the mounts f*cked Link to comment Share on other sites More sharing options...
