fordom Member 145 Member For: 15y 2m 12d Gender: Male Location: sydney Posted 27/03/13 08:52 AM Share Posted 27/03/13 08:52 AM Just wondering what would cause a knocking sound when braking at low speeds (only time I can hear it) in forward or reverse. sounds like it is coming from the front drivers side wheel area. Could it be a loose caliper as I had rotors and pads done 1500 kms ago?any help would be greatcar is a bf2 f6 Link to comment Share on other sites More sharing options...
jas98 Member 1,043 Member For: 12y 5m 13d Gender: Male Location: Maryborough Qld Posted 27/03/13 02:07 PM Share Posted 27/03/13 02:07 PM id check the caliper bolts and also control arm bush,s.....caliper bolts ASAP as you do not want them comming loose Link to comment Share on other sites More sharing options...
fordom Member 145 Member For: 15y 2m 12d Gender: Male Location: sydney Posted 02/04/13 06:01 AM Author Share Posted 02/04/13 06:01 AM well I took the wheels off and it wasnt caliper bolts and I grabbed everything under there and nothing was loose! very wierd Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 18d Gender: Male Location: Christchurch, New Zealand Posted 02/04/13 08:28 AM Share Posted 02/04/13 08:28 AM Is it a single knock when you start braking or continuous knocking while braking? Link to comment Share on other sites More sharing options...
fordom Member 145 Member For: 15y 2m 12d Gender: Male Location: sydney Posted 03/04/13 06:02 AM Author Share Posted 03/04/13 06:02 AM just a single knock when initially applying brake Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 18d Gender: Male Location: Christchurch, New Zealand Posted 03/04/13 07:45 AM Share Posted 03/04/13 07:45 AM It could be the pad shifting forwards and contacting the caliper on the initial application of the brake. It is an annoying noise but isn't really an issue. If your calipers have the stainless springs to hold the pad you can remove them and put a bend back in them to hold the pad still again. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 13d Gender: Male Location: Perth Posted 03/04/13 07:54 AM Share Posted 03/04/13 07:54 AM What brakes are fitted to it? Brembo's or PBR's? If PBR's your caliper slides could be worn, If brembo's your retainer pins could be bent,your pads springs may have lost tension or your pad contact pads inside the caliper could be worn/missing. Link to comment Share on other sites More sharing options...
fordom Member 145 Member For: 15y 2m 12d Gender: Male Location: sydney Posted 03/04/13 11:49 AM Author Share Posted 03/04/13 11:49 AM thanks, ill check out the pads againits brembo 4pots with ds2500 pads Link to comment Share on other sites More sharing options...
