Transmission Fault " P0735 " Nightmare
Davo1960
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 8d
Dont think Ull find one here in Australia period then lol
Bring de germanz to us now !!
And thanks
  • Member For: 21y 8m 2d
My suggestions of people to talk to would be either Martin Donnon at Willall racing or Simon at Nizpro for starters. Might be worth giving Rob Herrod a call as well.
Benny.
Edited by Benny
  • 6 years later...
  • New Member
  • Member For: 5y 9m 29d
Have you found the solution? I have same issue p0735-ff code. Problem occurred after I serviced the transmission. Apparently it wasn’t serviced before for a long time. But it was running trouble free except some lag when taking off from a stop. Lag is gone but this problem started. Fluid level has been checked many times. Initially I thought it’s the after market plastic pan/filter as filter neck/tube may be smaller and not sealing casuing internal leak. Tried metal pan conversion kit with separate filter but same problem. Car drives fine in general and I have traveled 1000kms in a day. But when it has to go through a lot of gear changes in traffic the problem occurs. Only fix is turn of the car and on again. If you have found the solution please advise.
 Thanks
  • 5 years later...
