  • Member For: 12y 4m 30d
Im looking to upgrade my fuel system with my next round of mods. The car (bf2) has been in my garage with a hdi cooler fitted for a while now. Looking at doing injectors, exhaust,tune and pump. Problem is the tuner I used on my last car has moved and the bloke I just spoke to doesn't seem too interested/helpful. (He's got a rep as a good tuner but average bloke). I explained I was only after average power (270-300rwkw tops). I suggested a walbro in tank upgrade and he told me the in tanks have problems with overheating and to go a PW surge tank. The price difference is about $700. Do I need this or will the walbro do the job easily and SAFELY? Keeping in mind I don't flog the snot out of it too often.
Im happy to spend the $ if necessary but would like some opinions.
Cheers
https://www.fordxr6turbo.com/forum/topic/84353-in-tank-upgrade-or-surge-tank/
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 16d
Safely is a loose word
How much u wanna spend on a rebuild if its not safe ?
  • Member For: 15y 7m 21d
IF you only want to run <300 and keep it above half a walbro will be fine
that's my point mate. If its wise to spend the extra I will but I've read about plenty of people running that power on in tanks with no problems. Just dont wanna be rorted
Edited by D DUB
Nah either way ull have a good peice of hardware that u can always sell at the end of the day for most of its cost
Aftermarket Intanks are 9/10 good for over 300
  • Member For: 14y 7m 28d
Its not a matter of the walbro being able to cope, its the surging issue. Any car with over 300rwkw can have issues with surging especially if you let the tank get low and decide to give her some.
I was in the same boat. Going to spend $300 for an intank pump with cradle or $1150 for new PW kit with walbro 460. Decided to go with the PW cause I couldn't be effed fueling up ever half a tank and for the extra $700-800 I have security that when a clubby wants to go you from a set of lights you don't have to check your fuel and decide not to smash him because your fuels too low lol
  • Member For: 19y 7m 25d
Cheers
Our advice would be a properly set up direct replacemant intank system .
When utilised as a package with a high flow regulator, correct wiring/.relay kit you will have no supply or surging issues well over 350 rwkw on a single pump or 600rwkw on a twin.
Completly legal, no noise or smells of the many external set ups.
Keep in mind that the currant 5.0 s/c GT at standard rear wheel power is anywhere from 300-345 rwkw.
This vehicle has no surge or supply issues even at near empty.
Ford did not use an external surge tank set up!
Currant U.S Mustangs with over 500 hp all use intank single pump or twin pump set ups.
These systems work perfectly when supplied and fitted correctly.
Edited by KPM Motorsport
  • Member For: 19y 14d
Cheers
My 2 cents...Be wary of marketing that is better than an actual product ;-)
Call some reputable tuners and ask what they think of in tank systems for high hp applications :-)
Kev
  • Member For: 13y 9m 6d
do it properly and go the intank and a pw surge with 044 pump off kev, you will not be disapointed, my theroy is go hard from the start so you dont have to go backwards in the future
