Barra Donating Members 467 Member For: 16y 8d Gender: Male Location: Toowoomba Posted 21/03/13 12:36 AM Share Posted 21/03/13 12:36 AM Hey guys. I need some serious help. About 1000kms after my last service, which included the front rotors being machined. I have been getting intermittent ABS and DSC faults which stay on until I cycle the ignition. It would be ok for a while in a straight line on a hwy (for 150kms) yet when I braked harsh or broke before a hard corner the faults would appear again. It was very frustrating as I had my young daughter in the car, so was stressing that the ABS was off.I took it to the workshop that serviced the car, they visually inspected the wheel sensors (did not remove them) and connected a scan tool-These 3 codes were there-C1288 - Pressure transducer main/ primary input circuit failure.U2501 - Missing token from engine management sys for ACCC1991 - Module calibration failure.Note- I saw these code descriptions on the scan tool, yet the mechanic only wrote the codes not the descriptions, I found these online. So I hope they are accurate.Also after mentioning that my cruise wouldn't work sometimes since all of this. They checked my brake lights. I watched as very intermittently upon pressing the brake, the lights would not light up. This is even more worrying. I've looked into a new brake switch which I confident I can fit myself. Could this switch be the cause of all my problems? Or what are the codes relating to? as the workshop have now referred me to Ford. Would rather get it sorted myself if I can.Thanks in advance for your help on this. Link to comment Share on other sites More sharing options...
Barra Donating Members 467 Member For: 16y 8d Gender: Male Location: Toowoomba Posted 26/03/13 01:48 AM Author Share Posted 26/03/13 01:48 AM Anyone?? Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 3m 25d Gender: Male Posted 26/03/13 02:37 AM Share Posted 26/03/13 02:37 AM (edited) C1288 is brake light switch, very common on fgIgnore other codes Edited 26/03/13 02:37 AM by bionicxr6t05 1 Link to comment Share on other sites More sharing options...
Barra Donating Members 467 Member For: 16y 8d Gender: Male Location: Toowoomba Posted 26/03/13 02:50 AM Author Share Posted 26/03/13 02:50 AM Thanks bionicBought one off ebay (genuine ford) the other day.Would this switch potentially be the cause of the ABS and DSC faults too?Haven't fitted the switch yet, assuming easy to do..? Looks like it just clicks in to a bracket and connect electricial socket. Link to comment Share on other sites More sharing options...
old_mate Member 767 Member For: 18y 9m 8d Gender: Male Location: Brisbane Posted 26/03/13 03:08 AM Share Posted 26/03/13 03:08 AM Brake switch fixes all. 1 Link to comment Share on other sites More sharing options...
broke Donating Members 229 Member For: 13y 1m 8d Gender: Male Posted 23/04/13 11:18 AM Share Posted 23/04/13 11:18 AM (edited) Hey guys, sorry hijack. Did some searching to find this. My FG has been throwing up DSC fail warning every other time I drive it. Goes away after ignition cycle but has come up at least a dozen times now. I don't have a code reader or anything like that. Car behaves perfectly normal even after the codes up. I did a battery disconnect and got about 5 days out of it before it started throwing it back up every second or third time I drive it. Going to have a chat to my mechanic tomorrow about it. Is it something a regular mechanic can look at? Or does it need to go back to Ford?CheersOh and probably a coincidence but the warning only started popping up after I filled up my tyres with air. Haha stretch I know but literally got the code on the way home from topping up the tyres. I'm wondering if too much tyre pressure can play with the sensor or it just happen to coincide with that. Edited 23/04/13 11:19 AM by broke Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 9m 22d Gender: Male Location: Sydney Posted 23/04/13 11:26 AM Share Posted 23/04/13 11:26 AM ummmmmmmmmmmmmmmmmmmmmmmmmmyeah im going to go with coincidence on that oneyou know the times when you should tell everyone whats going on, and there are times when you should keep things to yourself? this is one of those times. Link to comment Share on other sites More sharing options...
broke Donating Members 229 Member For: 13y 1m 8d Gender: Male Posted 23/04/13 11:33 AM Share Posted 23/04/13 11:33 AM yeah just wasn't sure, I filled up pretty tight. actually way over their rated pressure now I've checked. but I'll chat to the mechanic tomorrow anyway. Selling the car pretty soon just want to make sure it's all right before I move it. Link to comment Share on other sites More sharing options...
old_mate Member 767 Member For: 18y 9m 8d Gender: Male Location: Brisbane Posted 23/04/13 01:23 PM Share Posted 23/04/13 01:23 PM Brake switch fixes all. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 3m 25d Gender: Male Posted 23/04/13 08:51 PM Share Posted 23/04/13 08:51 PM Listen to old_mate 1 Link to comment Share on other sites More sharing options...
