2009 Fg Xr6T Knocking Noise
abbo69nz
  • 1 month later...
  • Member For: 14y 2m 9d
Keen to see you work out the cause Bellato, I have a similar clunk, ford said it has worn rear link pins (thought these should be a warranty item but apparently not?)
I've had the diff bush replaced twice under warranty 15k & 30k services, nearly due for the 60k so will ask them to check it again as I think it's gone again, was thinking of asking them if I buy a better than OEM bush would they fit it instead, anyone had any luck with them doing this?
