Rapidyellowxr6tute Donating Members 123 Member For: 13y 4m 2d Gender: Male Location: Yarra Valley, Victoria Posted 13/03/13 08:39 AM Share Posted 13/03/13 08:39 AM Hi Guys and Girls.I'm keen on a couple of the TSW wheels in 20" staggered for my FG ute but what I'm wondering is if the 20 x 10.5's for the rear will fit ok as they only seem to come with a 25 offset in the 10.5's or you can get them in a 20 x 9 rear with a 30 offset also. The fronts have a 40 offset so I'm hoping they will be fine also. Any advice would be appreciated as I want to order a set!Thanks very much......Worm or Henz????? lol Link to comment https://www.fordxr6turbo.com/forum/topic/84281-tsw-20-wheelsoffset-question-help-needed/ Share on other sites More sharing options...
mummba Member 525 Member For: 15y 2m 8d Gender: Male Location: perth Posted 13/03/13 08:48 AM Share Posted 13/03/13 08:48 AM go the 20x 10.5 +20's for sure 2 Link to comment https://www.fordxr6turbo.com/forum/topic/84281-tsw-20-wheelsoffset-question-help-needed/#findComment-1371354 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 22d Gender: Male Posted 13/03/13 09:24 AM Share Posted 13/03/13 09:24 AM +40 front will sit to far in.. You will need to run at least a 10mm spacer if not at least a 15mm 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84281-tsw-20-wheelsoffset-question-help-needed/#findComment-1371364 Share on other sites More sharing options...
Rapidyellowxr6tute Donating Members 123 Member For: 13y 4m 2d Gender: Male Location: Yarra Valley, Victoria Posted 13/03/13 09:35 AM Author Share Posted 13/03/13 09:35 AM Yeh, I sort of figured that Pazzo as the Vertini's I've got on there now are a +20 on the front and no rubbing issues at all with a 245/32/19. The reason I'm concerned about the rears is that I want to run a 275 or 285/30/20 because the 295/30/19's on the rear atm are fine and I have room to move and that's with a +35 offset. Just don't want to spend the coin and have rubbing issues but if I have to run a spacer on the front I won't be getting the TSW's. Link to comment https://www.fordxr6turbo.com/forum/topic/84281-tsw-20-wheelsoffset-question-help-needed/#findComment-1371371 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 21d Gender: Male Location: Victoria Posted 01/04/13 08:13 AM Share Posted 01/04/13 08:13 AM 20x10.5 +25 rear with 305/25/2020x8.5 +20 front with 245/35/20 Link to comment https://www.fordxr6turbo.com/forum/topic/84281-tsw-20-wheelsoffset-question-help-needed/#findComment-1376418 Share on other sites More sharing options...
