  • miso xr6
  • Member For: 16y 4m 23d
Hi guys, I keen to know what type of injectors people are using or prefer to use for daily e85 usage.
Reason I ask is because I have been using the bosch ev14 2000cc injector an it seems to me from my experience with these injector they do not like e85, just from one day use of e85 my 2000cc injectors will shut close or stick, I have had 3 injector failures already and iv pretty much had it with them.
Now I wonder if anyone has experienced the same issues iv had by using these type of injectors or any other types, by doing a bit of research it seems that there are lot of people that have had the same issue as me, it seems that issues arise because of a rubber seal inside the injector swelling by using e85 or fuels containing mtbe or are either oxygenated.
Anyways from what I can see the problems are only arising from using the bosch 2000cc or any other type of ev14 2000cc injector, so my questions are can anyone recommened a injector of similar size cc, there are a few other names out there like denso, siemens, dietchworks, has anyone used these other types injector?
And one more question can anyone clarify if pump e85 is oxygenated?
thanks
https://www.fordxr6turbo.com/forum/topic/84247-what-injector-do-u-use-for-e85/
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 1d
  • Member For: 18y 11m 5d
All ev14 injectors are bosch injectors.
Injector sizing should be determined by the power levels you want to run and type of fuel
  • Waiting for the 1st N/A 12!
  • Member For: 17y 2m 21d
Mate just get onto the black ops. The US guys rave about them they are purpose built multi fuel injectors and come in sizes ranging from 750 to 2000's.
I've been running them for over a year now and never had any issues.
Even Toads rates them now.
Also the way my idle is now sometimes you have to check the dash to make sure the car is on.
Edited by Vevapower
  • Member For: 17y 10m 7d
Interesting that you've had problems with this injector, I have been using the 2000cc for over a year.
What are the symptoms to look out for when this happens?
  • Member For: 19y 9m 24d
What makes you think they are sticking or holding shut?
Have you had them tested on a bench to confirm this is actually happening?
Jet those injectors you recommended are low-z.....no good!!!
  • RNS10S
  • Member For: 18y 8m 16d
I use 80lb dekkas which will not flow enough for Miso's needs but have not had any issues with them,
Could it be the type of e85 used?
Miso are you using United or e-flex?
