  • You've changed man....
  • Member For: 14y 4m 3d
  On 08/03/2013 at 10:27 AM, -SteveR- said:
Best
Thread
Title
Ever
Grow up
  • 570Nm @1800rpm
  • Member For: 21y 7m 9d
If you don't eat, your don't sh!t. If you don't sh!t, you die!
I think you need a dump.
  • Like 3
I think im being picked on :(
  • Member For: 14y 6m 11d
  On 08/03/2013 at 10:38 AM, Henz said:
This is gunna upset Jack, but Pete P ran 11.3@123 with stock Fg exhaust with hi flow cat, stock cooler, little turbo. 17 falling to 14
See I don't want to put that much boost into my car to achieve the same power/mph if I can put a dump and not worry about it. I want 14 down to 12 which I've seen has been down with a dump (no mph yet on its particular car).
And J@ feel free to rattle off fg's that you know of
I'm trying to make an informed decision so I only have to spend once and so far from the research that I've done there is a benefit to be had from a dump, but I'm open minded to other opinions (with facts to back it up) because at the end of the day if it's not really needed it will save me $$
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 30d
Whats the big deal to u about boost levels ?
That will come down to your tuner,and yes hardware but remember a characteristic of the small turbo is big psi in the mid ( hence nizpros famous 23 in the mid on steves car ) then taper off as efficiancy runs out
All engines are different urs may have to have 15-17 psi to make 330 so leave that up to the tuner and understand 17psi on a small turbo is nothing like 17psi on the bigger brother
But isn't running 14psi without an upgraded actuator bad enough let alone 17?
From what I understand more boost means turbo's working harder which means more stress on the bearings etc and can result in premature wear?
Mate your car will be turning out 330rwkw and ir worried about stress ??
Have a think about what uve just said
  • Here since the start...
  • Member For: 22y 5d
There's double that force in your tyres. I think the turbo will be fine.
Change the dump if you want to replace the cat without hacking up your standard exhaust.
