JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 2d Gender: Male Location: Adelaide Posted 09/03/13 12:29 PM Share Posted 09/03/13 12:29 PM It never seems to wear right even with a good vac bleed Do u have a genuine hot tip on this ralph ? Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370318 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 10d Gender: Male Location: Perth Posted 09/03/13 12:30 PM Share Posted 09/03/13 12:30 PM bleed them as per the FPV manual and you will get even pad wear:206-03B_-FPV_Performance_Front_Disk_Brake1.pdf Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370319 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 2d Gender: Male Location: Adelaide Posted 09/03/13 12:36 PM Share Posted 09/03/13 12:36 PM First I was thinking sticky pistons but that was after fraud had done a bleed the first time Made that chit assumption that they at least would do brakes right but seems like no Iam due to give it a full flush/bleed and ill do it this time Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370322 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 10d Gender: Male Location: Perth Posted 09/03/13 12:40 PM Share Posted 09/03/13 12:40 PM take pics.....start a thread....... Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370323 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 2d Gender: Male Location: Adelaide Posted 09/03/13 12:56 PM Share Posted 09/03/13 12:56 PM Yeh being informative is the new being a wanker Just trying to keep up Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370327 Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 5m 27d Gender: Male Posted 09/03/13 01:02 PM Author Share Posted 09/03/13 01:02 PM might as well replace all front rotors and pads soon. what pads do you guys use? dont think I'll go drilled brembo rotors, too expensive Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370330 Share on other sites More sharing options...
AF04XR Member 21 Member For: 12y 8m 13d Posted 10/03/13 04:38 PM Share Posted 10/03/13 04:38 PM I use DBA slotted and drilled rotors and just a cheap set of bursons pads they seem to last longer and pull up better than the bendix pads I've had no trouble at all with them Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370566 Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 5m 27d Gender: Male Posted 12/03/13 12:28 AM Author Share Posted 12/03/13 12:28 AM (edited) On 09/03/2013 at 12:25 PM, Ralph Wiggum said: Not if they are bleed properly. OP has air in the outside caliper side.Damn fraud probably introduced the air bubbles Edited 12/03/13 12:32 AM by sct911 Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/page/2/#findComment-1370926 Share on other sites More sharing options...
