JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 27d Gender: Male Location: Adelaide Posted 09/03/13 12:29 PM Share Posted 09/03/13 12:29 PM It never seems to wear right even with a good vac bleed Do u have a genuine hot tip on this ralph ? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 4d Gender: Male Location: Perth Posted 09/03/13 12:30 PM Share Posted 09/03/13 12:30 PM bleed them as per the FPV manual and you will get even pad wear:206-03B_-FPV_Performance_Front_Disk_Brake1.pdf Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 27d Gender: Male Location: Adelaide Posted 09/03/13 12:36 PM Share Posted 09/03/13 12:36 PM First I was thinking sticky pistons but that was after fraud had done a bleed the first time Made that chit assumption that they at least would do brakes right but seems like no Iam due to give it a full flush/bleed and ill do it this time Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 4d Gender: Male Location: Perth Posted 09/03/13 12:40 PM Share Posted 09/03/13 12:40 PM take pics.....start a thread....... Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 27d Gender: Male Location: Adelaide Posted 09/03/13 12:56 PM Share Posted 09/03/13 12:56 PM Yeh being informative is the new being a wanker Just trying to keep up Link to comment Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 21d Gender: Male Posted 09/03/13 01:02 PM Author Share Posted 09/03/13 01:02 PM might as well replace all front rotors and pads soon. what pads do you guys use? dont think I'll go drilled brembo rotors, too expensive Link to comment Share on other sites More sharing options...
AF04XR Member 21 Member For: 12y 3m 7d Posted 10/03/13 04:38 PM Share Posted 10/03/13 04:38 PM I use DBA slotted and drilled rotors and just a cheap set of bursons pads they seem to last longer and pull up better than the bendix pads I've had no trouble at all with them Link to comment Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 21d Gender: Male Posted 12/03/13 12:28 AM Author Share Posted 12/03/13 12:28 AM (edited) Not if they are bleed properly. OP has air in the outside caliper side.Damn fraud probably introduced the air bubbles Edited 12/03/13 12:32 AM by sct911 Link to comment Share on other sites More sharing options...
