sct911 Member 848 Member For: 12y 5m 12d Gender: Male Posted 07/03/13 10:55 AM Share Posted 07/03/13 10:55 AM (edited) I have a fg xr6t which has the 4pot brembo brakes in the front. Last week I dropped the car off at ford to get the diff bush replaced, a day later an annoying squeal started when braking. Now it has got worse and louder, when turning left without even touching the brakes the screeching noise still happens. When the steering wheel is straight or turning right, there is no noise. ford said they didnt touch the front end when replacing the rear diff bushes so I can't really blame them, cars also out of warranty. If I had to take a guess, I'd say noise is coming from the front. To test this theory I splashed a bucket of water onto the front wheels then went for a drive, the squealing stopped for a good minute then started again. front pads still have 40% left and rears have 60% leftAny ideas? Edited 07/03/13 10:56 AM by sct911 Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/ Share on other sites More sharing options...
HSV ETR Member 131 Member For: 12y 8m 27d Gender: Male Location: Brisbane Posted 07/03/13 11:23 AM Share Posted 07/03/13 11:23 AM if you say it stops screeching when you turn the otherway good chance its you wheel bearing. I have it in my ed work slu7 I just turn up the radio lol Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1369678 Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 5m 12d Gender: Male Posted 07/03/13 11:47 AM Author Share Posted 07/03/13 11:47 AM haha, I like fresh air, but the noise is driving me up the wall. Is it a cheap fix? Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1369691 Share on other sites More sharing options...
HSV ETR Member 131 Member For: 12y 8m 27d Gender: Male Location: Brisbane Posted 07/03/13 12:45 PM Share Posted 07/03/13 12:45 PM bout 50 buck (include bearing grease) and you can do it yourself shouldnt take any longer than a hour so id say 150 for a shop to do it.. that's if it is your wheel bearings sounds like it if u ask me Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1369724 Share on other sites More sharing options...
xr6thsveta Donating Members 100 Member For: 12y 11m 14d Gender: Male Location: Palmerston North. New Zealand Posted 08/03/13 10:51 AM Share Posted 08/03/13 10:51 AM Stone jammed in there somewhere? Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1370082 Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 8m 1d Posted 08/03/13 11:40 AM Share Posted 08/03/13 11:40 AM Lower ball joints put money on it over bearings Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1370100 Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 5m 12d Gender: Male Posted 09/03/13 07:30 AM Author Share Posted 09/03/13 07:30 AM just put the car on stands and checked it out, seems like ford missed a worn out pad. The pad on the inside of the front right caliper is completely worn out, while the pad on the outside still has around 40% left. Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1370241 Share on other sites More sharing options...
HSV ETR Member 131 Member For: 12y 8m 27d Gender: Male Location: Brisbane Posted 09/03/13 11:47 AM Share Posted 09/03/13 11:47 AM Bam! we were both wrong Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1370306 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 18d Gender: Male Location: Adelaide Posted 09/03/13 12:10 PM Share Posted 09/03/13 12:10 PM Typical for brembo pads to wear uneven dont stress its the way it is Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1370310 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 26d Gender: Male Location: Perth Posted 09/03/13 12:25 PM Share Posted 09/03/13 12:25 PM Not if they are bleed properly. OP has air in the outside caliper side. Link to comment https://www.fordxr6turbo.com/forum/topic/84230-squeal-screeching-noise-when-turning-left/#findComment-1370315 Share on other sites More sharing options...
