STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 3m 20d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 08/03/13 04:33 AM Share Posted 08/03/13 04:33 AM Ead 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1369908 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 16d Gender: Male Location: Adelaide Posted 08/03/13 04:36 AM Author Share Posted 08/03/13 04:36 AM ^^ hahaha ^^ Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1369911 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 4m 3d Gender: Male Location: Perth Posted 09/03/13 12:35 AM Share Posted 09/03/13 12:35 AM The T56 fluid change is easy enough but getting the reverse light switch out needed a special spanner........ an " adjustable type" which was an open ended spanner re-done with a grinder to make it thin enough and narrow to get behind the switch. After that, a cheap funnel and a length of clear fuel hose and a ladder to mount the funnel system for some flow and 4 odd litres of dexron 3 and its done.(Christ............ after reading that ... talk about primitive........ I should put a sign in the garage "VERY average automotives.") Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370167 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 24d Gender: Male Location: Perth Posted 09/03/13 12:57 AM Share Posted 09/03/13 12:57 AM Or you can just unclip the connector from the switch and use a 22mm/7/8" socket. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370170 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 7m 11d Gender: Male Location: Southern Highlands NSW Posted 09/03/13 01:59 AM Share Posted 09/03/13 01:59 AM So J@Whats the best method for flushing the tranny Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370185 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 16d Gender: Male Location: Adelaide Posted 09/03/13 03:33 AM Author Share Posted 09/03/13 03:33 AM I done it the old donkey way Drop pan, refill run through gears, drop pan, fill run through gears, drop pan then add new filter and complete fill 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370199 Share on other sites More sharing options...
f6mark Member 2,908 Member For: 14y 2m 2d Gender: Male Posted 09/03/13 04:06 AM Share Posted 09/03/13 04:06 AM Nice Right up jet. these car's need lots of love'n. Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370202 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 3m 22d Gender: Male Location: Melbourne Posted 11/03/13 02:08 AM Share Posted 11/03/13 02:08 AM jettershow do you flush coolant with hose?where do you shove the hose in? Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370646 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,410 Member For: 17y 7d Gender: Male Location: Melbourne Posted 11/03/13 02:58 AM Share Posted 11/03/13 02:58 AM Freaky, drain from white drain point on lower passenger side of radiator (engine-bay side). Open the yellow lid on the coolant bottle to allow to drain quicker.Flush with water from a hose if you want to do a complete job by putting the hose in the coolant bottle (with the drain still open), keep it running until water coming out of drain is the same colour as the water coming out of the hose into the overflow bottle, turn hose off, let it drain again. Replace drain plug, refill with either pre-mix coolant or post-mix coolant until at "cold minimum" level.Leave lid off the bottle and start car, pump up the aircon to max heat, let it idle until thermostat completely opens (normal water temp indicated on gauge), top up coolant bottle as necessary, put lid back on, take car for a drive around the street (10min or so), come back and check level again and top up as necessary. Check again a few times over the next week making sure there are no leaks and that the level stays stable Done. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370654 Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 7m 4d Gender: Female Location: SA Posted 11/03/13 03:12 AM Share Posted 11/03/13 03:12 AM Sorry who got u all tbe oils and filters and plugs? ??Ye your welcome donkey! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/page/3/#findComment-1370657 Share on other sites More sharing options...
