FiftyOne Bronze Donating Members 1,145 Member For: 11y 3m 16d Gender: Male Posted 28/05/15 06:19 AM Share Posted 28/05/15 06:19 AM (edited) I'd say you should be right as long as you can get it all in there. Worse case you might need a half litre of something dx6 compatible to top up. But the pans don't hold all that much really Iirc I put about 2.5l back in, ran it, dropped & repeated Edited 28/05/15 06:20 AM by FiftyOne Link to comment Share on other sites More sharing options...
hrick Member 210 Member For: 14y 10m 2d Posted 28/05/15 06:32 AM Share Posted 28/05/15 06:32 AM Cheers, my understanding is that 5.5litres ought to be enough. Link to comment Share on other sites More sharing options...
20pounds Member 180 Member For: 16y 23d Gender: Male Posted 07/06/15 02:01 PM Share Posted 07/06/15 02:01 PM So is everyone still happy with the GW? Link to comment Share on other sites More sharing options...
rob6155 New Member 2 Member For: 9y 4m 4d Posted 19/06/15 02:39 AM Share Posted 19/06/15 02:39 AM Hi AllMy BAXR6T wont reverse when hot,any suggestions pls(besides taking it to my usual dealer) Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 4m 17d Gender: Male Location: Adelaide Posted 19/06/15 04:24 AM Author Share Posted 19/06/15 04:24 AM Great thread to dump it in Don't use reverse when hot, that's a fix 2 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 10m 23d Gender: Male Location: Probably above atmospheric pressure Posted 19/06/15 06:14 AM Share Posted 19/06/15 06:14 AM Forums are probably confusing beasts the first time you use them. Threads? Topics? Sections? Bellbats? 1 Link to comment Share on other sites More sharing options...
rob6155 New Member 2 Member For: 9y 4m 4d Posted 19/06/15 09:00 AM Share Posted 19/06/15 09:00 AM well gee,thanx for the the help dudeI never would of thought of that. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 4m 17d Gender: Male Location: Adelaide Posted 19/06/15 09:02 AM Author Share Posted 19/06/15 09:02 AM My pleasure Link to comment Share on other sites More sharing options...
Choppers123456 New Member 1 Member For: 9y 2m 1d Posted 17/08/15 06:20 AM Share Posted 17/08/15 06:20 AM so guys how do you do a flush on a zf ? just bought the car with 131k and still has the plastic sump .... so looking at doin the steel sump convo and getting some gulf western syn trans atf ...have also heard Castrol transmax z does that box aswell ?? ...... but whats the best way to flush the old oil out of it ? have heard of leaving the old plastic sum on it and leaving the old fluid to drain for a couple of hours then fill it ...run it for a while the drain again this time changing to the new filter and steel sump and refilling it .... is this correct ? Link to comment Share on other sites More sharing options...
crazyxa Member 84 Member For: 17y 7m 6d Posted 24/09/15 09:09 AM Share Posted 24/09/15 09:09 AM (edited) so guys how do you do a flush on a zf ? just bought the car with 131k and still has the plastic sump .... so looking at doin the steel sump convo and getting some gulf western syn trans atf ...have also heard Castrol transmax z does that box aswell ?? ...... but whats the best way to flush the old oil out of it ? have heard of leaving the old plastic sum on it and leaving the old fluid to drain for a couple of hours then fill it ...run it for a while the drain again this time changing to the new filter and steel sump and refilling it .... is this correct ?That is the same as doing two services in a row so will still mix old and new fluids in the converter hence you will still not get all the old crap out. However it is still a good option.Now I never done this on a ZF however this works on a BTR (BA 4 speed).I run a tube from the outlet into a bucket or see through container. With engine on let the box pump it out fluid while you pump clean fluid in via the filler. On your own this will take a while as you can't keep up and pump in while it pumps out. It takes about 20litres to see ultra clean fluid come through.Now the above should also work with a tube connected to the bottom outlet on the passenger side. However not sure if thus is a good thing for the ZF oil pump under these conditions. Edited 24/09/15 09:24 AM by crazyxa 1 Link to comment Share on other sites More sharing options...
