PSI O6T Donating Members 440 Member For: 12y 4m 8d Gender: Male Location: sydney Posted 04/03/13 12:50 PM Share Posted 04/03/13 12:50 PM ok ,its a ba mk1 3/04 . calipers are silver in color,disks look smallish ,so im thinking ive got the standard xr6t brakes right ?question 1) can I put larger disks with the calipers I already have? 2) what size disks would be on the car ? 3) what size disks are the pbr premiums ? 4) what cars had the pbr premiums ?sorry for all the questions ,its just that the brakes on my car are the worst ive ever had..... Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 5m 10d Gender: Male Posted 04/03/13 01:28 PM Share Posted 04/03/13 01:28 PM (edited) I have a ba with the pbr upgrade and I have 325mm front rotors. I got told you couldUpgrade from factory or all ex cop cars have them...there also twin piston! Edited 04/03/13 01:30 PM by Kosij Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 3m 23d Gender: Male Posted 04/03/13 02:22 PM Share Posted 04/03/13 02:22 PM If standard brakes you'll have298mm fronts and 303mm rears Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 4m 8d Gender: Male Location: sydney Posted 04/03/13 10:02 PM Author Share Posted 04/03/13 10:02 PM (edited) whats the difference between the pbr premium calipers and the standard ones other than color ?also can I run 325mm fronts with standard calipers ? so many questions,lol Edited 04/03/13 10:05 PM by tresurehunt Link to comment Share on other sites More sharing options...
johno Donating Members 773 Member For: 14y 3m 10d Gender: Male Location: Mt Gambier, SA Posted 04/03/13 10:02 PM Share Posted 04/03/13 10:02 PM You can buy a bracket kit, and 325 discs off Ebay that let you use your existing caliper. BA GTs had premium PBR. Just fitted some to my 03 XR6T ute. Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 5m 10d Gender: Male Posted 04/03/13 10:50 PM Share Posted 04/03/13 10:50 PM The pbr are twin piston! And I haven't had a vibration issue even after about 120 passes down the 1/4 Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 1d Posted 04/03/13 11:13 PM Share Posted 04/03/13 11:13 PM There isn't a great gain to be had in upgrading disc size if the contact of the pad to the disc is the same. You'll only gain because the quality of the rotor would be better.If looking for a cheap upgrade get a front set of FG calipers and discs, as well as rear territory calipers and discs. Won't be too expensive and will be a massive upgrade from what you have now, especially if you use good discs ad pads 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 28d Gender: Male Location: Perth Posted 05/03/13 12:07 AM Share Posted 05/03/13 12:07 AM There isn't a great gain to be had in upgrading disc size if the contact of the pad to the disc is the same. You'll only gain because the quality of the rotor would be better.I disagree, a larger rotor give you a greater mass to absorb the heat generated by braking, it also gives you a greater leverage ratio @ the wheel hub compared to the smaller rotor. (greater moment of torque if I remember my high school physics correctly) Link to comment Share on other sites More sharing options...
BRK Member 361 Member For: 13y 1m 7d Gender: Male Location: Perth Posted 05/03/13 12:19 AM Share Posted 05/03/13 12:19 AM PBR premiums - BA Gt or were special order. 325 x 32 Front rotor / twin piston - unique caliper and pad ( not sure about the hoses). I can't remeber the rear set-up.BF Mk2 - 322 x 28 front rotor / twin piston - same caliper as territory. A fair system but nothing special. Rears are a 303 solid rotor with caliper to suit.In terms of upgrades the BA premiums are reasonably rated by most people. Race Brakes in Sydney sometimes have new kits. Second hand - well, its brakes and the calipers hoses etc are heading to ten years old so think about that if you find some.Rears - the very common territory offers a ventilated rotor ( 328??) and a different caliper to that of the BF2 - good upgrade and an easy fit IF you get all of the parts and ditch your dust shields.Territory Turbo runs a unique rotor package - nice but a bit rare.If the stock system is really sh*t it might just be pads...... funny how some people want these hipo cars and put 30 dollar pads in them and run the discs down to paper-thin. Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 1d Posted 05/03/13 12:54 AM Share Posted 05/03/13 12:54 AM I disagree, a larger rotor give you a greater mass to absorb the heat generated by braking, it also gives you a greater leverage ratio @ the wheel hub compared to the smaller rotor. (greater moment of torque if I remember my high school physics correctly)Okay listen to this guy he knows much more than me! 1 Link to comment Share on other sites More sharing options...
