JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 20d Gender: Male Location: Adelaide Posted 03/03/13 11:01 PM Share Posted 03/03/13 11:01 PM Yup seen that looks good So is your manifold still log style ? Link to comment https://www.fordxr6turbo.com/forum/topic/84185-split-pulse-housing-manifold/page/2/#findComment-1368534 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 9m 10d Gender: Male Location: Melb Posted 03/03/13 11:17 PM Share Posted 03/03/13 11:17 PM No. It's a extractors. Link to comment https://www.fordxr6turbo.com/forum/topic/84185-split-pulse-housing-manifold/page/2/#findComment-1368539 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 27d Gender: Male Location: Sydney Posted 04/03/13 12:49 AM Share Posted 04/03/13 12:49 AM As a guide I did some R&D testing 4 years ago with extractors that I commissioned a 3rd party to build (ETM), the 1st extractors in stock position, with stock turbo, by anyone to my knowledgeExtractors had a splitter to stop the gases interfering with each side.I watched the first dyno run after the install, with an overlay against the previous dyno run.Spool was 200-300rpm earlier, but car leaned out ..... this is where you need to be very careful.Car was then tuned. From memory picked up around 20rwkw up top. Tested with stock motor nizpro stage 2 kit.Car ran smoother and noticeably cooler. JP300 also tried extractors and got similar results.Once you go high mount, you can run a much bigger turbo, and good for show.My Nizpro stage 5 has big turbo, but in low mount position, design theory was to to reduce heat.Brian 1 Link to comment https://www.fordxr6turbo.com/forum/topic/84185-split-pulse-housing-manifold/page/2/#findComment-1368566 Share on other sites More sharing options...
juggernaut Member 71 Member For: 15y 11m 12d Posted 29/03/13 01:40 AM Share Posted 29/03/13 01:40 AM (edited) I run a split pulse manifold/ (twin scroll) exhaust housing on my sr20 powered S15 running a GT3076 turbo and use dual wastegates, with supporting mods.In this form it makes around 290rwks's but the beauty of this setup is in the transient response and part throttle response because it spools earlier rather than out and out hp. My bum dyno tells me there is no more lag than the standard setup in the lower rpm, with a very linear power delivery, so its not like a light switch which can happen on smaller displacement motors and bigger turbo's. IMO these setups are best suited to smaller displacement motors where exhaust pulse energy can be used to the best extent to spool the turbo up earlier. For this reason most production cars now utilise twin scroll tubos in there current crop of production cars - Subura, Mitsubishi, BMW, Mini and the list goes on. Here's a link to my setup which is on the Full Race Motorsport website in the US (where I sourced my turbo kit). Note that the pics are with my old 3071 setup. and have since swapped to a 3076 (52trim) setup and 3.5inch dump (up from 3 inch dump.http://www.full-race.com/store/turbo-kits/nissan-sr20det-rwd-twinscroll-gt30r-turbo-package.htmlCurrent setup....3076 (52trim) twin scroll housing and 3.5 inch dumpshowing twin wastegates Edited 29/03/13 01:49 AM by juggernaut Link to comment https://www.fordxr6turbo.com/forum/topic/84185-split-pulse-housing-manifold/page/2/#findComment-1375637 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 20d Gender: Male Location: Adelaide Posted 29/03/13 02:25 AM Share Posted 29/03/13 02:25 AM Looks great bloke and to have minimum to nil lag makes for a great ride And yes some do not like the sledge hammer boost rush Link to comment https://www.fordxr6turbo.com/forum/topic/84185-split-pulse-housing-manifold/page/2/#findComment-1375641 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 21d Gender: Male Posted 29/03/13 03:12 AM Share Posted 29/03/13 03:12 AM And on your second question about low/high mount, I definately will go out of my way to fabricate a low mount in favour of a high mount in a Ford Falcon. A turbo will melt everything around it, especially your master cylinder. You want to keep that turbo away from your master cylinder. But not only this but also your bonnet. That is why Ford did a low mount.You can have a high mount with a turbo on the passenger side of the engine (like the sr20) and cop any bonnet paint issues, but a master cylinder melting is a safety issue. Yes you can use shielding but that can only do so much.Also the exhaust works out much better with a turbo low mount as you don't have that horendous first 90 degree bend and easier to get a 4" in there.Space is tight but I think you get a better result. Link to comment https://www.fordxr6turbo.com/forum/topic/84185-split-pulse-housing-manifold/page/2/#findComment-1375655 Share on other sites More sharing options...
juggernaut Member 71 Member For: 15y 11m 12d Posted 29/03/13 03:47 AM Share Posted 29/03/13 03:47 AM On the question of high or low mount - this will depend on the physical size of the turbo in which case a high mount might be required to package it in the engine bay. Regarding heat issues I don't see there being much of a heat difference between the mounting positions if you use a tubular exhaust manifold because the most of the heat radiates from the manifold runners themselves moreso than the turbo exhaust housing. In the case of a low mount the tubular exhaust manifold runners will radius up from the flange plate then back down to the low mounted turbo - placing the runners near the bonnet and around other engine bay components anyway. Further, it is far easier to sheild a high mount tubular manifold (runners are place lower in the engin bay) than a low mount tubular manifold runners placed high in the engine bay). If your using a cast low mount log exhaust manifold then that's another story - they radiate a lot less heat than an aftermarket turbular manifold - but I doubt you would be using a cast log manifold if using a twin scroll turbo setup in your Ford. I have a turbo beanie on my turbo exhaust housing (which is also ceramic coated inside and out) and you can touch it after it has been running. I have no problems with paint bubbling on the bonnet as yet either - and suspect I never will have. As I mentioned above the greatest source of heat is from the runners of the tubular exhaust manifold - and its like a furnace. Link to comment https://www.fordxr6turbo.com/forum/topic/84185-split-pulse-housing-manifold/page/2/#findComment-1375664 Share on other sites More sharing options...
