  • Waiting for the 1st N/A 12!
  • Member For: 17y 3m 14d
Hi all,
Just thought I’d post a bit of a photo journal of my recent Engine & Diff flush and re oil using Mainlube products.
See below what I used:-
  • 2 x GTX Mineral oil or any crap mineral oil you can get cheap. Just recently
    Repco ran the 4ltr varieties out the door for $5 this is all you need. Must be
    a mineral oil though.
  • Cheapest Gear oil you can find, I just used the Penrite stuff ($20) but I’m sure there
    is cheaper stuff out there.
  • Mainlube Engine Flush Additive
  • Mainlube Gear Oil 75w140 appearance is as red as red can be.
  • Mainlube 10w60 appearance Avocado/Olive.
  • FilterMag RA300
  • Filtermag TM360 transmission Pan App
First Get the car in the hoist and drain both the Engine and Diff oil.
Then we re filled with the Mineral Engine oil and the Diff oil and the instructed amount of flush for both Engine and Diff. 11/1 is the ratio.
Now its time to let the car run and ilde for approximatley 20 mins with say every 5 mins jumping in the car and bringing the revs up to 2200 for say 30 secs.
We decided to kill two birds with the one stone by jacking up the back, chocking the fronts and slipping it into drive. This way we cover both the engine and the diff flush at the same time. Possibly I little bit dodge but no damage done.
We then simply dropped both the Engine and Diff oil and re filled using the Mainlube Oils.
10w60 Mainlube Engine Oil with secret herbs and spices!
Mainlube 75w140 Gear Oil that is the redest liquid I think I've ever seen!
Now the simple intsall of the Pan Magnets. *****Warning if you have never played around with strong earth magnets before be very very careful, I literally almost broke my finger off holding them and moving to close to a tool box***** Scared the Barjesus out of me.
Then fit the Oil filter Magnet. (for illustartion purposes only, forgot to take pic of my one)!
And all done!
Ready to go racing.
TjpHK.jpg?1
I'd like to say a special thanks to CMS for the use of his shop, hoist, staffer and Kingston bikkies! http://www.cmssydney.com.au/
Also a special shout out to Aaron and Peter from Mainlube. http://www.mainlube.com/cms/
Links below to the mainlube Oil bulletins used in this service:-
Gear Oil - http://mainlube.com/cms/uploads/File/154%20SB.Synthetic%20Solid%20Boundary%20E%20P%20Gear%20Oil(wos)%20pdf.pdf
Enigine Oil - http://mainlube.com/cms/uploads/File/175%20Synthetic%20Racing%20Engine%20Oil%20(wos).pdf
  • Like 2
  On 27/02/2013 at 10:16 AM, ratter said:
hope you cleared the ABS codes when you finished ;)
Certainly did!
  On 27/02/2013 at 12:06 PM, Philthy18 said:
What are the magnets you have put on the pan being used for?
Pulls all the bits of metal that the ZF filter can;t catch go the floor of the pan. When you drop the pan at next service you simply remove the particals.
It's all about removing the metal from your oil so your parts dont wear.
Same with the Oil filter.
Check this pic out below of an oil filter cut open after 10k's while have the filtermag on it:-
Edited by Vevapower
  On 27/02/2013 at 12:35 PM, Ford Freak said:
yo good write up
where do you get the magnets from?
Mainllube sell them as well.
  • RNS10S
  • Member For: 18y 9m 9d
Good write up Matty, I can also vouch for the Mainlube stuff, using there gear oil in the diff and recent testing found the oil to be in tip top shape.
Yeah must say the quality of the oil that's been coming out of George's and my cars recently could almost go back in.
Testimate to the Mainlube oils really.
