The Converted Donating Members 344 Member For: 13y 5m 13d Gender: Male Location: Melbourne Posted 28/02/13 08:28 AM Author Share Posted 28/02/13 08:28 AM New brake switch didn't resolve the problem. Link to comment Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 17y 11m 14d Gender: Male Location: Gladstone, Queensland Posted 28/02/13 09:08 AM Share Posted 28/02/13 09:08 AM Are you setting the switch correctly, I dont know what the other boys do but I used to grab the plunger with my teeth and hold the switch in my hand and pull, you will hear a crunching noise when it comes out, then put it back in its hole, before you do the push the brake on and off a few times, you need to be careful you dont move the brake pedal away from the switch plunger as you install as it wont give a correct adjustment for the plunger at the brake off position Link to comment Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 5m 13d Gender: Male Location: Melbourne Posted 28/02/13 09:11 AM Author Share Posted 28/02/13 09:11 AM My xcal 3 is still returning a fault code for 'brake switch ckt'. My cruise control can now be armed and set when the car is first turned on, but after the first time that I push the brake pedal, the honeymoon is over. Is there any chance that the arm on the new booster is too long and is allowing the brake pedal to come out further - in turn pushing the plungers in too far and damaging the switch? Link to comment Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 5m 13d Gender: Male Location: Melbourne Posted 28/02/13 09:13 AM Author Share Posted 28/02/13 09:13 AM I held the brake pedal out when I installed the new switch, then once it was clipped in I released the pedal. It sprung back and made the switch crunch a couple of times. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 6m 24d Gender: Male Posted 28/02/13 09:16 AM Share Posted 28/02/13 09:16 AM (edited) Whoa!!! When installing a brake switch in an fg or ba/f all you do is push the switch into the hole and twist to locate it... Never ever pull the plunger out or touch the pedal when u locate it or you will damage the switch Edited 28/02/13 09:16 AM by bionicxr6t05 Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 6m 24d Gender: Male Posted 28/02/13 09:19 AM Share Posted 28/02/13 09:19 AM Also ba/f have 2 switches both should be done at the same time Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 3m 25d Gender: Male Location: Far north queensland Posted 28/02/13 09:21 AM Share Posted 28/02/13 09:21 AM time to get the credit card out again Link to comment Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 5m 13d Gender: Male Location: Melbourne Posted 28/02/13 09:21 AM Author Share Posted 28/02/13 09:21 AM Well f*ck. Looks like switch #3 will be the go. The plunger was sticking out of the switch body too far to just be pushed in and twisted which is why I moved the pedal away to put it in. :( Link to comment Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 5m 13d Gender: Male Location: Melbourne Posted 28/02/13 09:23 AM Author Share Posted 28/02/13 09:23 AM Only getting fault codes for the brake switch, not the cruise switch. Should I still replace both?My question relating to the length of the cabin side push rod of the booster still stands. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 6m 24d Gender: Male Posted 28/02/13 09:57 AM Share Posted 28/02/13 09:57 AM Ahhh have you compared the length of the pushrods between old and new boosters? Link to comment Share on other sites More sharing options...
