  • Bronze Donating Members
  • Member For: 13y 9m 4d
Like any modification you should always get it checked but changing to a marginaly more effective cooler will not change much
  • 570Nm @1800rpm
  • Member For: 21y 7m 10d
Seaton, I fitted an F6 cooler to my Euro4 XR for the same reason. Massive visual improvement :spoton:
I don't have a picture with the bumper back on yet as but below are a couple of pictures to give you an idea.
  • Like 2
  • Member For: 19y 8m 16d
Just did this also last weekend. ~1.5 hrs including a trip to autobarn for some replacement scrivets. Could not believe how easy the front bar comes off and obviously the f6 just bolts in, that part is probably 5 minutes.
I would recommend before starting get replacement scrivet things, the 3 that clip the liner into the wheel arch on each side. They a sh*t to try and remove and keep like new. There are 3 each side, the larger Christmassy tree ones holding the lower mad flap come in/out just fine as do the ones holding the grill in place above the radiator.
  • Member For: 12y 8m 4d
Thanks for heads up mate, I work in a smash repairs, all those clips come out pretty easy, and should be able to reuse no problem. Good trick for the Christmas tree ones is is use some side cutters to pull them out. Get them under the head and just grip and pull. The screw head ones, undo the screw in the middle, then same thing, side cutters under the clip to lever them out if you don't have the proper clip remover tool.
What are people paying for a tidy, used FG F6 cooler?
  • 570Nm @1800rpm
I had no problem removing and re-using any of the clips here.
Seaton, I was not willing to pay over $300 and waited until something came up that was reasonable. Ended up getting mine for under $300, but I did keep an eye on forums classified, ebay and gumtree for a few months until a decent one popped up.
  • Member For: 15y 6m 9d
did you buy yours off the guy on gumtree that was 200?
I messaged that guy when he first put it up for sale and he wanted 450 but would drop to 400 bucks lol
  • 570Nm @1800rpm
Here are a quick snaps with the bumper back on. Growler intake scoop is covering the top right corner of the cooler.
