Choliver_36 Donating Members 40 Member For: 13y 10m 6d Gender: Male Location: Darwin Posted 24/02/13 01:27 AM Share Posted 24/02/13 01:27 AM So apparently the two piece tailshaft is terrible Mine is going to ford on Monday and I'm just wanting to know if any of you are getting under the car or have been can you check and see is this is what it should look like.. Otherwise it could be my diff Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/ Share on other sites More sharing options...
michaelhardy Member 104 Member For: 16y 6d Posted 26/02/13 09:53 AM Share Posted 26/02/13 09:53 AM doesnt look good.. Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/#findComment-1366758 Share on other sites More sharing options...
nitro xr6 turbo Banned 185 Member For: 13y 7m 10d Gender: Male Location: perth wa Posted 26/02/13 10:06 AM Share Posted 26/02/13 10:06 AM yes, they truely are a piece of sh*t!I see so many fords with buggered center bearings. its hard to see from the pic, but get a hold of the tailshaft and push it up and down, if you can see a split in the rubber that holds it then its f***ed.they are cheap and verry easy to replace on the other hand, unlike some cars. so dont pay through the nose for it, nearly any workshop will beable to do it, unless youre still under warrenty ofcoarse, then get ford to fix their own mistake. Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/#findComment-1366765 Share on other sites More sharing options...
OED666 Member 129 Member For: 19y Gender: Male Location: Gold Coast, Qld Posted 26/02/13 11:15 AM Share Posted 26/02/13 11:15 AM Of the car has any sign of axle tramp it will just happen again! Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/#findComment-1366802 Share on other sites More sharing options...
XR6T PIG Member 54 Member For: 13y 26d Gender: Male Location: sunny coast Posted 27/02/13 01:48 AM Share Posted 27/02/13 01:48 AM could this cause vibrations while in drive Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/#findComment-1366960 Share on other sites More sharing options...
fehlbie Donating Members 142 Member For: 16y 2m 23d Posted 27/02/13 04:58 AM Share Posted 27/02/13 04:58 AM I have heard that you can use a Late model camira centre bearing as they are a stronger unit, but I have only heard about it. Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/#findComment-1367035 Share on other sites More sharing options...
OED666 Member 129 Member For: 19y Gender: Male Location: Gold Coast, Qld Posted 27/02/13 12:43 PM Share Posted 27/02/13 12:43 PM They don't suit, as they do not suit the carrier. Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/#findComment-1367252 Share on other sites More sharing options...
fehlbie Donating Members 142 Member For: 16y 2m 23d Posted 15/03/13 03:43 AM Share Posted 15/03/13 03:43 AM (edited) 35mm ford f150 centre bearings look like a good fit? And they look a lot better built too. Edited 15/03/13 03:43 AM by fehlbie Link to comment https://www.fordxr6turbo.com/forum/topic/84108-centre-bearings-are-shte/#findComment-1371898 Share on other sites More sharing options...
