XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 9m 14d Gender: Male Location: Perth, WA Posted 18/03/13 06:05 AM Share Posted 18/03/13 06:05 AM Having recently fitted King SSL front and rear springs with OEM shocks that are 20000kms old, I would strongly advise changing the OEM shocks at the same time as fitting the springs.While the car does ride ok and is a bit firmer, it is clear that the shocks are out of their optimal operating parameters and do not "absorb" shocks no where near as well as they did with stock springs. Also the car can be a bit bouncy especially when more than one passenger is on-board. Not terrible, but definitely not good either. Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1372685 Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 9m 23d Gender: Male Location: sydney Posted 18/03/13 11:03 AM Share Posted 18/03/13 11:03 AM im running lows front and sssl rears all with standard shocks. Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1372763 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 9m 7d Gender: Male Posted 18/03/13 01:45 PM Share Posted 18/03/13 01:45 PM I'm running standard shocks.. My rear springs move around when going off bumps though Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1372800 Share on other sites More sharing options...
xr6boosted Member 67 Member For: 13y 5m 9d Gender: Male Location: QLD Posted 23/05/13 05:22 AM Share Posted 23/05/13 05:22 AM My BA is standard shocks and springs all round, I just want to flatten the rear end slightly without going to town replacing everything. Has anyone gone SSL springs in the rear and left the front standard? Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1392101 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 16d Posted 23/05/13 09:41 AM Share Posted 23/05/13 09:41 AM In a BA you would create a fair amount of rake doing that and would look funny. Why not just go sl front if you're concerned? Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1392166 Share on other sites More sharing options...
xr6boosted Member 67 Member For: 13y 5m 9d Gender: Male Location: QLD Posted 23/05/13 10:11 PM Share Posted 23/05/13 10:11 PM Because the front is already lower than the rear, I just want to even it out. Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1392297 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 28d Gender: Male Location: SW Sydney Posted 24/05/13 02:04 AM Share Posted 24/05/13 02:04 AM Just fit an SL to the rear, SSL in the rear and standard in the front will settle un-even. The SL in the rear won't change much to start with, but once they settle it will be even Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1392357 Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 9m 23d Gender: Male Location: sydney Posted 24/05/13 05:55 AM Share Posted 24/05/13 05:55 AM +1 for sl in the rear with std xr6 fronts to even it out. Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1392391 Share on other sites More sharing options...
xr6thsveta Donating Members 100 Member For: 13y 2m 1d Gender: Male Location: Palmerston North. New Zealand Posted 24/05/13 10:07 AM Share Posted 24/05/13 10:07 AM I thought that sl was the same height as xr6 standard springs?And to drop it approx 25mm you had to put ssl in?So if you wanted to level the rear end with the standard front you would need ssl rears?And to lower the whole car and make it level all round you would need ssl front and sssl rearOr am I one "s" too low? Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1392453 Share on other sites More sharing options...
xr6boosted Member 67 Member For: 13y 5m 9d Gender: Male Location: QLD Posted 27/05/13 03:54 AM Share Posted 27/05/13 03:54 AM that's what I thought too.. Also based on previous experience with kings, they tend to sit lower in the front and never seem quite low enough at the rear.A 20mm drop in the rear would be ideal to match where the front currently sits. I'm getting diff bushes done anyway and was thinking a pair of SL or SSL might have to go in at the same time. Hey if I find I have made a terrible mistake and it's dragging it's ass like a Bankstown/Lakemba SSS pulsar, I could always put some SL in the front to fix it up.Thanks guys. Link to comment https://www.fordxr6turbo.com/forum/topic/84087-do-i-need-shortened-shocks-for-ssl-rears/page/2/#findComment-1393011 Share on other sites More sharing options...
