jas98 Member 1,046 Member For: 12y 7m Gender: Male Location: Maryborough Qld Posted 20/02/13 01:51 PM Share Posted 20/02/13 01:51 PM (edited) Ever gone to the track and done hard stops from 200kph?in my VS commodore, yeah done that, with slotted rda standard rotors and the stadard qfm pads.....never warped but they did fade lolto original poster, is your calipers ok? and brake booster? also after you stop check the wheels, if there f*cking hot then it sounds like your brakes are dragging causing heat build up Edited 20/02/13 01:52 PM by jas98 Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 10m 23d Gender: Male Posted 20/02/13 02:13 PM Share Posted 20/02/13 02:13 PM It could just be the pads. I had Bendix CT pads on a set of new discs (unknown as put on prior to me purchasing the car) and after 5000km of sedate driving were starting to shudder. I replaced the pads with Ferodo DS without any machining and whilst they shuddered in the beginning, they are now to the point of no shudder after a few thousand Ks due to the Ferodos being a bit more agressive and leaving the disc cleaner.But in saying that all these disc look the same when its the metalurgy that really determines how good it really is. The more you pay the better I think. Link to comment Share on other sites More sharing options...
BRK Member 361 Member For: 13y 2m 9d Gender: Male Location: Perth Posted 20/02/13 02:14 PM Share Posted 20/02/13 02:14 PM (edited) The RDA's are back on the terry now with Bendix pads. I'll see how they go. The amount milled off the rotors was minimal according to the brake place. The brakes grabbed and the judder was really noticeable - anyway, I'll report back. This car is a stocker. I went with RDA as the supplier reckons they sell these to the trade. Anyway, if they turn bad again, DBA will be the next fit.My T has had no issue with the std 322 factory rotor and pads. No track days but a bit of spirited driving from time to time. They are coming up soon so maybe the DBA slotteds might be a good upgrade and perhaps Bendix ultimates , Ferodo or the QFM pads? Edited 20/02/13 02:15 PM by BRK Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 9m 6d Gender: Male Location: adelaide hills- 'race air' central Posted 20/02/13 09:18 PM Share Posted 20/02/13 09:18 PM im a big fan of the bendix ultimates... Link to comment Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 6m 5d Posted 20/02/13 09:57 PM Share Posted 20/02/13 09:57 PM (edited) Ferrodo ds ftw with DBA T2 best pads I have used so far and have uses both Bendix and QFM I went with the ferrodos as no one seemed to give them ago must have put them in the same time a turbotrana give them ago in n my opinion supplier eBay if you carnt source them locally also sell T2's and T3 reasonably priced from same seller Edited 20/02/13 09:58 PM by spinr33 Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 26d Gender: Male Location: @ my laptop Posted 20/02/13 11:25 PM Share Posted 20/02/13 11:25 PM It could just be the pads. I had Bendix CT pads on a set of new discs (unknown as put on prior to me purchasing the car) and after 5000km of sedate driving were starting to shudder. I replaced the pads with Ferodo DS without any machining and whilst they shuddered in the beginning, they are now to the point of no shudder after a few thousand Ks due to the Ferodos being a bit more agressive and leaving the disc cleaner.But in saying that all these disc look the same when its the metalurgy that really determines how good it really is. The more you pay the better I think.Not sure on what type of rotors you are using, but have been told not to use CT's on slotted or drilled rotors, heavy duty are better in that application Link to comment Share on other sites More sharing options...
FPVF6355 Member 128 Member For: 14y 1m 4d Posted 17/03/13 10:54 AM Author Share Posted 17/03/13 10:54 AM The calipers, and brake system is all in good nick. I kept driving on it for a bit longer, and the right side rotor is blue between each slot.When the guy machined them, the same side was the side that seems to be the issue.No I don't sit with my foot on the brakes after a hard stop.I think 1 rotor is just dodgy.I honestly think 325mm is too small for 1850kg and 300+ kw. Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 4m 6d Gender: Male Location: sydney Posted 17/03/13 11:00 AM Share Posted 17/03/13 11:00 AM ever thought it may be your driving style and not your rotors... Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m Gender: Male Location: Maryborough Qld Posted 17/03/13 12:58 PM Share Posted 17/03/13 12:58 PM u sure the caliper is not seizing? ???? on that side Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 2m 4d Gender: Male Location: North West Hot Hell,VIC Posted 17/03/13 07:45 PM Share Posted 17/03/13 07:45 PM As above, You may have a problem with the slide on that caliper.Had one binding up at work last week with that issue. Link to comment Share on other sites More sharing options...
