blackxt Member 19 Member For: 13y 20d Posted 18/02/13 09:09 AM Share Posted 18/02/13 09:09 AM hi allive been toying with the idea of fitting my gas research stuff I have on a old turbo crossflow falcon to my ba turbo . the thing im struging to get my head around is how I would get it to work as I have todo away with fly by wire for it to work , wich unless I can get the car to run with its ecu with only a tps and a cable thottle , or adapt gas research to run the fly by wires stepper motor is the only way it will work , and both things I dont think will work .my plan atm was to go stand alone ignition , lock the vct and just run the gas research all very basic , the thing I dont no is how I will run the dash and all the sensors and so on , how much does the ecu run is really my question .if I set it up basic and just left the ecu hooked up with out the injectors and ignition hooked up what would happen ,I no I could just use vapor injection , but its very messy and has its restrictions I no I can get alot more hp out of gas research .and still if its all to hard ill just stick with petrol and give up .eny ideas or help would be great . Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 5m 8d Gender: Male Location: @ my laptop Posted 18/02/13 09:17 AM Share Posted 18/02/13 09:17 AM do you want a legal system?What's the build date of your car?What sort of power are you chasing?How will you get more power out of a mixer ring system? Link to comment Share on other sites More sharing options...
blackxt Member 19 Member For: 13y 20d Posted 18/02/13 09:39 AM Author Share Posted 18/02/13 09:39 AM do you want a legal system?What's the build date of your car?What sort of power are you chasing?How will you get more power out of a mixer ring system?its a 05 mark2 ba turbo ,the gas system is legal with the way I will set it up ,350rwk plus would be great pritty much as much as I can get using just one mixer ,and gas research is not so much of a gas ring system , it flows much much more .they have run some very fast times on gas research , and you can still have a nice clutter free engine bay is the main reason I like it , if I could do away with all the injection stuff and just make the engine run of the basics I could make it all very tidy , I have a 6 speed manuel also so no need to run the auto. Link to comment Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 2m 19d Posted 18/02/13 09:41 AM Share Posted 18/02/13 09:41 AM If you want a throttle body instead of the gas research one a fg one 08 to 11 I think dedicated gas would work, has fly by wire and also gas input similar to the old gas research throttle body's would make the process a lot easier and would not be hard to get hold of.If you look at fg dedicated gas cars 8 to 11 should give you a fair idea of how to pull it off using the older style glass systems .Good luck and keep us updated if you go this way Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 5d Gender: Male Location: Adelaide Posted 18/02/13 09:41 AM Share Posted 18/02/13 09:41 AM Haha extreme best of luck with that Link to comment Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 2m 19d Posted 18/02/13 09:46 AM Share Posted 18/02/13 09:46 AM I've seen a vl turbo with twin converters and a gas research throttle body go over 350kws can be done this was like 8 years ago aswell lol Link to comment Share on other sites More sharing options...
blackxt Member 19 Member For: 13y 20d Posted 18/02/13 09:57 AM Author Share Posted 18/02/13 09:57 AM I've seen a vl turbo with twin converters and a gas research throttle body go over 350kws can be done this was like 8 years ago aswell lolthat's gas 747 , there a pritty hypo orange mustang kicking around , all built by the same man. and a 700hp turbo v8 ltd built by a guy from act, since they jacked the gas prices up its hardly worth it but I just like gas as its differnt , and with gas research the mixer and throttle bodys all is one thing , need to use the gas research throttle body . Link to comment Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 2m 19d Posted 18/02/13 08:50 PM Share Posted 18/02/13 08:50 PM Actually the vl I'm referencing is one my mate built haha who was a mechanic from daylesford used to rip skids everywhere back in the day, are you sure those gas research throttle body's have built in converter s I just looked over their website as I thought they have have changed years later but doesn't appear to have have you got a link to the one you plan on using ? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 5m 8d Gender: Male Location: @ my laptop Posted 18/02/13 11:44 PM Share Posted 18/02/13 11:44 PM 05 model car needs an emission tested and complient system, Link to comment Share on other sites More sharing options...
