  • Member For: 13y 4m 25d
thanks guys! I'm from penrith :) my old car was a dash green xr6t which is around penrith also plates are HO74RD,
thought I better do the right thing and go FPV this time and will never look back!
yes a few things going on next month & CV
are the last guys to tune it which made 300kws for a safe run in tune.
will be going to CMS with the following upgrades next month... Stage 3
intercooler kit with cast throttle elbow, process west in tank surge
tank, 1000cc injectors, process west fuel rail, turbosmart bov. with a
tune joe said with this turbo should be over 400kws :)
whats done to the car so far...
Stock F6 injectors
•Engine block chemically cleaned
•Block decked and line honed
•Aries forged pistons
•Atomic steal rods
•Crank micro polished
•Atomic race harmonic balance
•Atomic head and main studs
•Atomic oil pump gears
•Atomic heavy duty timing chain and new guides
•Cylinder head serviced with new crow valve springs
•Turbo rebuilt new bearing pack
Exhaust house mod done with ported waste gate and 32mm flap new .7 comp housing and 66mm wheel
•battery relocation kit
•4 inch ceramic coated dump 4 inch cat into 3.5 inch single exhaust
•Transmission rebuilt while engine out all solenoids replace new bands and extra clutch for top gear converter split
and checked new external trans cooler with braided lines. by the way the box shafts are still stock which was going to do when
box was apart but didn't end up doing it
•Rear
suspension cradled dropped all bushes. Replaced with supa pro nolathane
bushes, bilstien shocks and pedders lowered springs
•Front radius rod bushes changed to nolathane with more caster
Nolathane Sway bar bushes
