Swi-Jack Install - Steering Wheel Controls
kochxr6
  • Member For: 14y 1m 19d
Keen to get my steering wheel controls working again and ive had one of these for a while but because they are American there is no info on the wiring connections for falcons??
So has anyone actually installed one of these themselves? Just need to kno where to tap into on the car and what wires to use on the unit. Any help would be appreciated.
Ok so I figured it out. For anyone interested in doin this it is pretty easy.
Basically just connect the red wire on the PAC to switched positive off your CD player and black wire to ground. Then splice the white wire from the PAC into the red/white wire under the steering colum (do not cut this wire it also does other stuff)
Once these connections are made plug the headphone jack (from the PAC) into the back of your CD player then follow the instructions to program it.
My CD player is an alpine so set the dial to 1 and used version 3 to program.
You can buy the PAC from eBay for about $50 if anyone is interested in having a go at it
