  • Member For: 13y 13d
Well I'm changing the fuel filter which is only 16000kms old.. The fuel pump is walbro gss341 and injectors seimens 60lb only 6000kms old.. Suppose ill just go through the motions..
Filter, plugs, coils.. Then ill be off the the tuner get the fuel pressure checked I suppose..
Anyone got any better ideas?
Thanks
  • Member For: 18y 11m 12d
best idea is to test rather than guess, normally works out a lot cheaper than just chucking parts at it.
put it this way, everybody here can have a guess, I'm sure somebody will guess correctly, but at the end of the day unless we have your car to test, we are all just guessing..................................
................ at your expense
  • I <3 Floods
  • Member For: 13y 9m 8d
Ratter again with the sensible information..
Back in your corner..
  • Member For: 12y 9m 16d
just throwing ideas around....what about your battery? that can cause probs if stuffed?
also throttle body?
intake gasket?
cam sensor wiring?
like I said just throwing ideas. I doubt you brought non genuine coils but who know, you can get one dodgy one even if its the best dam item in the world!
