  • Member For: 19y 11m 26d
No...I actually asked to pay for one and he wouldn't let me. Even payed for express postage. Who does that!!!!! Like I said.....bloody legend!
  • 5 weeks later...
Yeah 6BOOST low mount, however mine is a T4 with ex gate and I have a 1.06 T4 split pulse turbine housing for the GTX35.....the GT3566r on the stock log manifold is to laggy for my liking. Hoping to recover a few hundred rpm in spool that the 66mm wheel robed from me!
Well I have finally got around to sorting my set-up. I haven't tuned it yet and need to put in a heavier wastegate spring, but initial thoughts are that it's still too laggy for my liking. Probably comparable to the GT3566r on the stock manifold. Once on boost though it revs out very smooth and the car is definately making more power.
As Trana predicted, heat is an issue! I've had to try and heat proof everything. Yet to make something for the master cylinder and I'm pretty sure it's going to need it.
  • Member For: 15y 3m 28d
nice work mate,
wat size rear housing did you eventually go with? I have put on a precision 6466 in a 1.04 rear with a 6 boost hi mount, would be good to see differents's between the 2, mine being manual was going for as quick a spool as possible
and same as you heat is crazy under bonnet, though pcpa have got turbo blankets on sale atm for $90, helped a bit
Very nice! Mine is a 1.06 twin scroll so it is quite sizey compared to a conventional T3 1.06. Mine is all ceramic coated but feels like it has done squat lol. Oh my is manual too so was keen for quick spool, but it could be better TBH.
What gate and psi spring have you got in yours? I'm in Perth also, would be good to catch up.
yeah mine also is a t4 twin scroll, could be a 1.06 actually come to think of it, I originally was going to go a t4 0.84 but glad I didn't as boost comes on so faarkin hard as is, is hard to tune the gate pressure in properly...
im running twin precision 38mm gates with 2 springs equalling 14psi I think, will double check that,
will definatly have to catch up, would like to check out your setup and pick your brain a bit haha
edit; I also got my manifold and housing ceramic coated, and heat wrapped my dump and screamers but HOT!!!!
Edited by mummba
I can show pics of the heat shield Luke......and the melted coolant overflow lol. Best you be test driving it instead :-)
The 6466 is a big turbo, its compressor inducer is 2mm bigger than the GTX35...but more importantly the exhaust turbine exducer is 4mm bigger also. So its no surprise it's rated at 900hp compared to the GTX's 750hp. I think they have a 1.00 and a 1.15 A/R rear......a 1.15 would be stupid so you must have the 1.00. I reckon it would be a very interesting comparison and I would be keen to do a few quick data logs to get some decent comparison on manifold pressure vs RPM! Are you using the factory boost control?
  • Member For: 22y 3m 3d
I did a low mount tubular TO4z on my ED with a high mount wastegate, Heat was still ridiculous that it melted the master cylinder. I did an ally heat shield and still pretty hot. The old log manifold that I had on this ED was much better from heat and reliability aspect.
yeh I would really like to see the difference between the two, boost comes on surprisingly fast and very early,
na mate im running eboost 2
