  • Member For: 12y 9m 23d
true its settled then however in saying that if I do choose to get a manifold and I do make more power on the same if not less boost would that some how make my motor last longer than a setup with a stock manifold running more boost??
  • miso xr6
  • Member For: 16y 5m 6d
I have a very similar set up to what you are referring to, my set up consists of a etm tuned length manifold gtx3582r turbo an 48mm external wastegate.
Using this set up I managed to make more horse power with less boost, much quicker spool, and great boost control.
Edited by CCCC
  • Member For: 22y 1m 15d
Its not all about power. A high mount tubular manifold will cook everything around it. Your bonnet paint work, your master cylinder and other bits and pieces. So if you are just want moderate 400kw save your time fixing up the above.
  • Member For: 16y 3m 25d
  On 17/02/2013 at 2:13 AM, J Ravs said:
I emailed Kyle from 6boost about this very thing he told me he had a set up but it was not really worth it unless I was going to external waste gate ect. Witch made me really confordent in 6boost as a company that there not in it for the money. Other people on this site can probably vouch for this better than me. But I would be emailing or calling Kyle and telling him your plans and he will recommend the best way to go.
I can vouch for this. Kyle's honesty has saved me a lot of money over the past 4 years.
I cant even get him to spend my money on doing a 4 link for my ute as he believes it will be a waste of money. His advice has been invaluable throughout my whole build process.
  • 1 month later...
  • Member For: 12y 1m 21d
I was stuck on 380rwkw in 2010 with to4z comp wheeled gt35 put the low mount 6 boost manifold on with exact same setup made 403rwkw and the sound and power delivery was allot more exhilarating
  • Member For: 15y 6m 19d
only change was manifold and retune?
yeap tune and manifold only changes ran this setup until last week when the oil pump let go
