  • Member For: 14y 6m 11d
  On 26/02/2013 at 7:05 AM, jas98 said:
any update? mines doing tha same, worse when raining and everything is new
Been busy getting back into uni so car's now booked in on saturday for them to have a look. The guy there was pretty unhelpful when I told him my problems but anyway wait and see when they put it on a hoist and have a look
  On 26/02/2013 at 11:47 AM, Goliath said:
Had the same problem. Was resolved after tightning the bolts around the rear swaybar bushes. It looked tight to me, but I still tried to tighten it up.
Yea been under the rear of the car and tightened everything up. Only problem was when I did it the car was jacked in the air and wasn't on a hoist so it is possible that because the load wasn't on the wheels some bolts appeared tight but once the car is on the ground they actually aren't.
  • 1 month later...
  • Just a large member member
  • Member For: 16y 6m 14d
Have a look at exhaust..If I stand behind my car and kick the tail pipe to the right..D/S I get a knock..Could be exhaust hitting something..
So went to another suspension shop wednesday and they said my upper outer bushes and lower outer (not toe arm the other control arm) bushes are farked. now I took the right rear wheel off to replace the brake hose bracket and there seems to be a bit of play in the upper bush but its not stuffed. Is it going to be noticeable to the naked eye if these rose joints (?) are farked? Never really dealt with bushes like that before and showed my old man and he said the same.
it's a relatively cheap fix but a bit of a pita of a job and I'm kind of over wasting money when its not fixing the problem, I want to try be sure that they're stuffed.
Again the car only has 90,000kms so it seems a bit young to have all these supposedly shagged bushes
  On 12/04/2013 at 9:17 AM, johnxr6t said:
Spare tyre is secure?
I thought I had a rattle/knock in my rear suspension and it was my spare tyre.
Yea not that, pulled it out of the car n still had it
