Bellato Donating Members 2,713 Member For: 14y 6m 19d Posted 15/02/13 02:56 AM Share Posted 15/02/13 02:56 AM I posted up a while ago about this knock/thud I had in the rear of my FG and tried a few things to no avail. I finally thought it had come good after changing the diff bushes but it has now returned!So its an 08 FG sedan with 87,000kms with zf on ssssl springs and monroe gt sport shocks.I've also changed the control blade bushes to pedders ones and diff bushes to super pro comfort's.I've been under and checked every nut and bolt, checked every bush and can't see anything that's worn outIt only happens over really sharp bumps.Anyone else had this issue or can offer any light onto other things I may be able to try? I've already been to one ford dealer and 2 suspension shops and no one can tell me what the problem is. It gives me no confidence to drive in a spirited way because you feel like somethings gonna let go on me!Thanks! Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 15d Gender: Male Location: Perth Posted 15/02/13 03:05 AM Share Posted 15/02/13 03:05 AM check your top shock mount bolts Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1363073 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 1d Gender: Male Location: SW Sydney Posted 15/02/13 04:43 AM Share Posted 15/02/13 04:43 AM When you say sharp bumps do you mean short quick bumps like a road join or large changes in elevation that would put the suspension through its range of travel? Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1363097 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 6m 19d Posted 15/02/13 06:41 AM Author Share Posted 15/02/13 06:41 AM Top shock bolts are tight.Yea short quick bumps like road joins, train tracks etc pat.I got under the car again with my old man n tried to find something but no luck! Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1363123 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 11d Gender: Male Posted 15/02/13 07:42 AM Share Posted 15/02/13 07:42 AM Rear link pins or rose joints Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1363148 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 6m 19d Posted 16/02/13 01:24 AM Author Share Posted 16/02/13 01:24 AM Sorry about my ignorance but are they the joints connecting the rear sway bar?If so I had a play with them and doesn't feel like there's any movement. Should they be taken off to inspect? Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1363337 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 11d Gender: Male Posted 16/02/13 02:36 AM Share Posted 16/02/13 02:36 AM Yes the link pins connect the swaybar to the lower control arms, if the bush is cracking they are stuffed, rose joints are also a major cause of annoying rear end knocks Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1363351 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 6m 19d Posted 16/02/13 05:58 AM Author Share Posted 16/02/13 05:58 AM Thanks mate! I have to head back to canberra 2moro morning for uni and no point getting under the car now because couldn't get the parts even if that's the problem.Might go to pedders and get their $14 check and ask them to check the link pins and rose joints and if they need replacing just bite the bullet and get them to do it or what till im back in Griffith when I have access to tools etc.I can't imagine there being anything major because the suspension all over the place, just annoying to hear it all the time Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1363391 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 15d Gender: Male Location: Maryborough Qld Posted 26/02/13 07:05 AM Share Posted 26/02/13 07:05 AM any update? mines doing tha same, worse when raining and everything is new Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1366678 Share on other sites More sharing options...
Goliath Member 383 Member For: 14y 9m 23d Gender: Male Location: Sydney Posted 26/02/13 11:47 AM Share Posted 26/02/13 11:47 AM Had the same problem. Was resolved after tightning the bolts around the rear swaybar bushes. It looked tight to me, but I still tried to tighten it up. Link to comment https://www.fordxr6turbo.com/forum/topic/84013-rear-end-knock-need-help/#findComment-1366813 Share on other sites More sharing options...
